Pre 84 Trucks 1st gen pickups
where do i get a new tvsv???
Old 01-05-2011, 01:37 PM
Sgt'sYota's Avatar
So after bout a full day of chasing down vacuum leaks from the p/o i am left with just one. the tvsv between the carb and valve cover w/ 3 line hooked to it is cracked at the bottom. i cant find it anywhere online. and the toyota dealer said disscontinued. so my question is where do i come up with one. we dont have any good junkyards or Pick a parts here. the part number i need is 90925-02060. thanks everyone.
btw this is on a 1980 4x pickup w/ 20r.
Old 01-12-2011, 05:33 PM
herpestes's Avatar
is this the valve that you are trying to replace
Old 01-12-2011, 08:44 PM
MudHippy's Avatar
Hopefully it is, and hopefully you're willing to part with it. Because the dealer, strangely enough, was right on this one.
Toyota Part 90925-02060
OEM Toyota VALVE, THERMOSTATIC VACUUM SWITCHING, NO.1
The part you are looking for is NOT Available.
Fit Vehicles: (Production Date Range; Engine; Trim; Body Type; Door; )
Toyota Celica
1979.08-1980.08; 4cyl 2.2L; LT; CP; ;
Toyota Corona
1979.08-1980.08; 4cyl 2.2L; LE; SED; ; 1979.08-1980.08; 4cyl 2.2L; DLX; SED; ;
1979.08-1980.08; 4cyl 2.2L; LE; LB; ; 1979.08-1980.08; 4cyl 2.2L; DLX; LB; ;
1979.08-1980.08; 4cyl 2.2L; LE; WG; ; 1979.08-1980.08; 4cyl 2.2L; DLX; WG; ;
Toyota Truck, Pickup
1979.08-1980.08; 4cyl 2.2L; DLX; ; ; 1979.08-1980.08; 4cyl 2.2L; STD; ; ;
1979.08-1980.08; 4cyl 2.2L; SR5; ; ;
Old 01-12-2011, 09:28 PM
herpestes's Avatar
don't know if this is the correct valve. there is a aisin 25810-27010
part number on the valve body. let me know if this is the correct one.
Old 01-13-2011, 12:41 PM
Sgt'sYota's Avatar
it doesnt look exactly the same but real close. on mine instead of the top one pointing up mine points the same direction as the other 2.
Old 01-13-2011, 02:02 PM
herpestes's Avatar
Sgt'sYota...........check your pm
Old 05-12-2015, 10:47 PM
81 Toy Four Wheeler's Avatar
TVSV Valve What do you use to seal threads?
My toyota semi-drying liquid gasket 00295-1LG04 no longer available, What do I use on these threads that goes into the water system? Thank you Charles https://www.yotatech.com/forums/imag...es/exp_rig.gif
Old 05-13-2015, 06:45 AM
mwisham's Avatar
I would use teflon tape
Old 05-13-2015, 10:08 PM
thread sealing for tvsv
My First thought was teflon tape , It winds off as it threads, still like the idea, called Edelbrock Gasgacinch Tech line said teflon tape too. I also found Permatex 65 to 300 degrees Thread sealant #80632 with teflon at Auto zone. I called Perma Tex about thread sealant durability, and if can be removed. The Perma Tex tech confirmed that this product is removable, not a cement. It does take 24 hours to set, and the port has to be completely dry. Their site stated, use with temperature sending fittings, hydraulic, air, oil etc. I worked in Aerospace always trying to get best results. Thank you for responding, Charles
Old 05-14-2015, 05:16 AM
mwisham's Avatar
If you wrap the tape in a clockwise direction with the threads facing you, the tape will not unwind as you screw it in, it will wrap tighter as it goes in. You have to make sure to wrap the tape in the direction of the threads. I have been a heavy duty truck mechanic for forty years and we use teflon tape on just about any fluid and/or air fitting on the semi's.
Old 05-14-2015, 05:30 AM
konah's Avatar
Worked in aerospace, can't wrap Teflon tape properly. Sounds like the joint U.S European muck up with metric and standard measurements!
Old 05-15-2015, 11:51 AM
Thank you mwishham for taking your time and responding. I understand the wrap direction, but did not know it wraps tighter as it goes in, not to be concerned about the little bit you see after it is tight. The Toyota factory manual stated thread sealant. This will clear-up any doubt. Thanks, Charles, Happy Four Wheeling!
Old 01-16-2016, 07:41 PM
83SR5LB's Avatar
I realize this an old thread, anybody ever find a tvsv? I need to replace mine, it has the port that sticks up and two horizontal, discontinued part, 90925-02069, any lead or info is appreciated.
Old 01-17-2016, 05:00 AM
MudHippy's Avatar
I just found out recently that AIRTEX\WELLS is making them now...for the 3VZ-E at least. Which is great...for some of us.
http://www.rockauto.com/catalog/more...nid=567&jpid=0
Even though the OEM part, 90925-05047, is still available. And cheaper.
Old 01-19-2016, 11:53 AM
83SR5LB's Avatar
Just found it at toyotaonlineparts.com, they list the 25810-27010 for $67.54 plus shipping I think. toyotapart.com has the photo and it is $75.19, plus shipping.
Got the answer from Amayama parts in Japan and they are discon.
kawazx636
10-06-2021 03:03 PM
kawazx636
02-23-2016 11:57 AM
Lons81
11-26-2012 02:35 PM
Quick Reply: where do i get a new tvsv???
