Pre 84 Trucks 1st gen pickups
Where to buy stock replacement leaf springs
Old 06-27-2012, 07:11 PM
83BluePickup's Avatar
I recently picked up a stock 83 4x4 pickup and the leaf springs are flat or bending upside down. I can't find stock height leaf springs. Everywhere is 4-6 inch lift. I need front and rears. Any help is appreciated.
Old 06-27-2012, 07:26 PM
Old_ blue's Avatar
http://www.4by4connection.com/4runpicallle.html .....Fronts are stock. Im not sure if there are rear leafs that are stock but u could add an add-a-leaf to even it out if its not even.
Old 06-27-2012, 07:54 PM
4x4YOTA's Avatar
those are stock to light duty load not stock height leafs they are 50mm (2") lift and the HD leafs are about 100mm (4") lift
if money is not a problem call up alcan http://alcanspring.com/ and have him build you a new set of springs...
also the stock front leafs have slight negative arch from the factory
but if you want cheapish new "stock" height front springs check out this company
http://www.customsuspension.com/stor...th=147_215_216
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Where to buy stock replacement leaf springs
