Pre 84 Trucks 1st gen pickups
Weber Carb Install Questions.
Old 04-10-2010, 02:03 PM
Jeffp's Avatar
What should I do with the holes circled in red. Plug them? And does the vacuum advance look like it is done correctly? I also installed a new radiator and hoses. When i started the truck it began to leak coolant out of the white part on the temperature switch mechanism cirlcled in yellow. I need to know the correct name for this so i can purchase a new one.
Attached Thumbnails Weber Carb Install Questions.-part-2.jpg   Weber Carb Install Questions.-part-3.jpg   Weber Carb Install Questions.-part.jpg
Old 04-10-2010, 02:41 PM
84YotaBuck's Avatar
The hole in your first pic is where my PCV valve hooks up to and yes the vacuum advance is right. I'm running a 32/36 in mine, had it for about 2 years.
Old 04-10-2010, 02:43 PM
xxxtreme22r's Avatar
the pic on the left there should have been a barb fitting for it, the hose that goes to it goes to the pcv valve (back hose connection on the valve cover.)
Your vacuum line to the distributor is correct assuming the other end goes to the ported carb connection.
The valve (right photo) is the heater valve. should be part number 87240-89117
Old 04-11-2010, 04:33 PM
Jeffp's Avatar
thanks buddy
kazuya2416
04-05-2024 02:17 AM
PNWrider
10-30-2015 08:14 AM
Yota.Jay
07-23-2015 08:08 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Weber Carb Install Questions.
