Pre 84 Trucks 1st gen pickups
Turn Signal Flasher Location
Old 08-13-2011, 02:20 PM
neockder's Avatar
Searched and Searched.. and can't find anything for our trucks. I can find every other relay, but can't find the turn signal flasher!
I've found electrical diagrams and everything, but still can't locate where the turn signal relay is. My horn is inop as well, so I'm assuming the relay is bad.
Has anyone replaced this slash know where it is located behind the dash?
Thanks for the help!!
Old 08-13-2011, 11:02 PM
neockder's Avatar
This is literally all i've found.. I've located the 'turn hazard switch' but can't seem to find the flasher.. any help is greatly appreciated!
Old 08-14-2011, 09:13 AM
Fossilized
Staff
dropzone's Avatar
Check the P/S kick panel...
Old 08-14-2011, 05:58 PM
slacker's Avatar
turn your hazards on .. you'll hear it
Old 08-14-2011, 06:04 PM
igotit's Avatar
im assuming hes asking because his flasher relay went out....meaning you wont hear the notable clicking.
The following users liked this post:
Jeff McDaniel (01-30-2020)
Old 08-14-2011, 06:12 PM
dougstoys's Avatar
Also check the firewall just above your pedals.
Old 08-14-2011, 07:40 PM
Rigor's Avatar
What year(s?) is that wiring diagram for anyway? Or are all the 1st gens similar? This may prove useful...
Old 08-15-2011, 06:37 AM
slacker's Avatar
I realize this !!
most people dont know there link'd .. instead of explaining , its just easier to suggest that
Old 08-17-2011, 12:50 AM
neockder's Avatar
Originally Posted by slacker
I realize this !!
Sorry, I think i misused the word flasher.. The hazards work, but the turn signals don't. I thought the turn signal relay and hazard relay are different.. are they not?
Going to take a closer look once i get the second bucket seat in
It's a 1980 diagram
Old 08-17-2011, 06:45 AM
slacker's Avatar
they are the same flasher .
sounds like either a ground issue , or possable in the combi. switch itself ..
do the sign. lights come on and stay on , you have ALL 4 lamps connected ?
Old 08-17-2011, 07:45 AM
neockder's Avatar
Yep, replaced the bulbs all around. I need to find some side marker lamps and every light will work. Almost ordered a turn signal assembly last night, but shocked at the price new! Want to sell me one from your parts rig?
Jealous of your frame off.. Going to start a build thread once i get a little more along.. Planning on pulling the bed and sandblasting the rear half of the frame and bed this winter.
Drove the truck off property for the first time this morning, not bad up to 35! Can't wait to bring this truck back from the (sitting on a farm) dead!
Old 05-29-2014, 02:47 PM
neockder's Avatar
Originally Posted by hervit
Tacoma 99 2.4 turn signal no work
Please help locatiom flashers signal
Man I love posts like these..
Oh, PS - it was the column switch that was the culprit. I ended up modifying an '82, and using the parts from each to make a complete switch assembly, and now i've got the capability for intermittent wipers. If anyone wants to upgrade from non-intermittent wipers, I'll scan both electrical plug diagrams I wrote out so you can map the wires correctly.
Old 08-17-2014, 09:45 AM
welder7018's Avatar
on my 79 relay is above passenger kick panel . turn signals on my truck only work when my wife drives it she says it likes her better
Shoua
13
05-22-2016 05:19 AM
kvanzandt1
07-18-2015 10:15 AM
Hamonacracker
07-17-2015 08:33 AM
jetspeedz
07-13-2015 09:32 PM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: Turn Signal Flasher Location
