Pre 84 Trucks 1st gen pickups
Trekker Trouble
Old 12-04-2013, 04:39 AM
81 Toyo's Avatar
[QUOTE=If you are ever crazy bored someday...a few hundred pics of your truck would actually help me alot in my trekker restoration. Hell Id even pay for your time if need be.[/QUOTE]
No charge for advice!...we are all in this together. Heres one picture anyway. I lucked out when I found this one on Craigslist awhile back....everywhere I go people ask me to sell it, even while crusing down the highway yelling to me out their window, and I'm not kidding...
If theres something in particular you want a pic of to help in your restoration just let me know.....Kevin
Old 12-04-2013, 10:33 AM
trekkerinhawaii's Avatar
I can't stop staring. It's just so pretty.
Old 12-04-2013, 10:36 AM
gillesdetrail's Avatar
Beautiful.
Old 12-04-2013, 01:38 PM
Any tricks for getting photos to upload? Having trouble. Anyways picked up fuel pump today, hope to get that in after work. Do I need the spark plug socket to get the plugs out? Replacing those and wires and cap/rotor today too. Thanks for the vids and the help. No joke this is the most extensive auto work I've ever done. Growing up finally at a much older age.
Oh and what about tie rod arms? Midas said I should replace mine too, where to buy, what to get, is it a DIY or should I take it in..
Mahalo
Old 12-04-2013, 01:44 PM
  #25
RobotMoose's Avatar
Tie Rod Ends can be sourced from the dealer. I believe they're very affordable.
The cheater's TRE install is to take a notepad with you, so you can count and record how many turns each TRE takes to unthread from the tie rod. Then when you install the new ones, thread each one on the same number of turns the corresponding old TRE took to remove. Your adjustment should be about ballpark where it was.
The cool thing about all your repairs is that the parts are all very affordable, everything is just a bit time consuming. That's what racks up the prices: shop time.
We'll all be glad to help in any way, good luck!
Old 12-04-2013, 01:50 PM
  #26
Rowdydudeman's Avatar
omg... that thing is beautiful! when i grow up, i want my 82 to be that pretty!
Old 12-04-2013, 03:43 PM
  #27
trekkerinhawaii: is it your only car? do you have the place to work on it? If you have not much mecanical knowledge and can afford to learn working on this truck it is a great place to start. The tie rod ends are easy to replace but I suggest getting an alignment done afterwards unless you can put them exactly where they were before. You can also search for ''home made alignment'' that can be done with a couple of 2x4s. Don't hesitate if you have anymore questions.
Old 12-04-2013, 09:48 PM
  #28
So tonight I was able to finish changing the fuel filter and the fuel pump. I was not able to finish the spark plugs, etc. One of the screws on the cap used to be a phillips screw, however now its stripped. Suggestions to get this screw out so I can finish replacing spark plugs, cap, and rotor.
I started it up after replacing the pump and filter and same thing happened. It ran for a few seconds, and then died.Tried it numerous times, tried foot on gas pedal, tried pumping gas pedal before starting, it never flooded, just wouldn't stay on.
Could it be the spark plugs? I am taking this next step regardless, but could this be the issue? How do I know how tight to make the plugs when I put them back in?
Yay for another day of having the babysitter take me to work.
Photo help? Anyone? Mine won't upload.
Old 12-04-2013, 10:27 PM
  #29
RobotMoose's Avatar
Plugs should come with guidelines on the box, generally "thread in until tight (do not overtighten) and back X number of turns".
Photos: the easiest way to deal with those is to register with Photobucket, and upload your pictures onto the site, then copy and paste the address for each specific photo and format the address like this:
[img]photoformatexample[/img]
Just replace "photoformatexample" with the URL and you'll be good to go.
Old 12-04-2013, 11:13 PM
  #30
cman1's Avatar
Originally Posted by cman1
vacuum leak,get some propane or carb cleaner and spray around.welcome!!!
did you check for vacuum leaks? mine did the same thing, hit the gas it would start and run while your pumping the gas, let off and it would die, my pcv valve hose that goes into the intake was cracked on the side you couldn't see. sooooo.
Old 12-04-2013, 11:40 PM
  #31
As far as spark plugs go, do not overtighten them, usually you just have to slightly compress the ring at the base of the thread, and I highly doubt changing them will fix the issue but it is part of a good tune up.
Old 12-05-2013, 08:58 AM
  #32
Being the newbie here can you explain how i would check for this in more detail?
Stripped screw suggestions so I can replace the cap?
Old 12-05-2013, 11:20 AM
  #33
RobotMoose's Avatar
Vacuum leak finding. As a quick suggestion, I would advise using one of those green propane bottles instead of carb cleaner. Modern carb cleaner is detergent based and doesn't affect the idle like old school carb cleaner.
One of those cheapie thread-on torches unlit will do the trick.
Old 12-05-2013, 11:32 AM
  #34
83
83's Avatar
First step would be to just take off the air cleaner, if it obstructs your view at all, and visually check to see that no vacuum hoses are hanging loose, unattached to anything. Look around the car and emissions stuff and make sure there are no nozzles without hoses attached to them.
If that checks out, then while the engine is running (ha!), spray around the base of the carb, and all the vacuum hoses. If the idle speeds up when you spray around an area, it's got a leak. If it speeds up when you spray right down the barrel of the carb, that's normal
I don't understand what your second sentence means.
Old 12-05-2013, 11:34 AM
  #35
83
83's Avatar
My trucks have no screws on the spark plugs, wires, cap or rotor...
Old 12-05-2013, 12:19 PM
  #36
The video is informative thanks. BUT, if my truck will not stay on for more than 2 seconds, it appears to me that I cannot do this test. I am going to replace all the vacuum hoses around the carb tonight, maybe that will fix it.
On my truck the black cap thing (i thought it was called the cap, i may be wrong) where the spark plugs wires go into from the spark plug has 2 screws holding it in place. One of the screws is stripped. How do yall get a stripped screw out?
Old 12-05-2013, 12:26 PM
  #37
83
83's Avatar
Photos would be sooo nice.
I have gone so far as to file two flat spots on opposite sides of the head, and use vice grips on stripped screws.
I know the attitude from personal experience...but you're doing a lot of "throw money at it", rather than trouble shooting. You could save a lot of money by spending the time to actually figure out what's wrong.
A. you'll replace a whole bunch of crap, problem is gone, but you have no idea what the actual problem was. So if it happens again someday...are you going to replace every one of these things again?
B. The problem still won't be fixed and you've spent all this money.
Old 12-05-2013, 01:00 PM
  #38
KauaiRunner11's Avatar
83 is right, it might take a little more effort, but you'll thank yourself when you look back at your reciepts, especially in Hawaii. Not sure what island you're on, I sent you a PM, let me know if I can help.
Old 12-05-2013, 07:26 PM
  #39
RobotMoose's Avatar
Can you make it idle by either upping the idle speed or keeping the throttle open partway? Generally speaking, vacuum leaks or timing issues can be offset enough for diagnostic purposes by holding the throttle open on the carb a bit while doing your work. When my T-chain jumped 2 teeth, I was able to limp it into the shop by cranking the idle speed up stupid high and limping it on the backroads on 2 cylinders.
#2 in this picture I've shamelessly pilfered from the internet is the idle speed screw.
Dude, you rock!
I'm glad to see some local help being offered here!
Old 12-06-2013, 04:08 AM
  #40
81 Toyo's Avatar
You stated "one of the 2 screws in that black cap thing is stripped"....I assume you mean the distributor cap, if one of the screws is stripped and the cap is only held on by one screw than that could be the problem. The rotor inside spins around it may not be making contact very well with each spark plug contact because the cap is loose....just a thought worth checking.
Quick Reply: Trekker Trouble
