Pre 84 Trucks 1st gen pickups
temperature gauge broke?
Old 01-18-2012, 10:05 PM
funcrazy1's Avatar
So I have 1980 2wd yota and I will go to start the truck in the morning when its cold out and I turn the key once and the temperature gauge shoots to instantly hot.. Is this bad sending unit? How can I find the sending unit its a 20r engine. Please help me
edit----
Thanks guys Fixed the problem love knowing my temp now
Old 01-18-2012, 10:08 PM
Staff
Terrys87's Avatar
I have fixed a couple of the sending units just by getting the green gunk off of it. I just use a green scrubby pad or brass wire brush.
Old 01-18-2012, 10:23 PM
funcrazy1's Avatar
So it is a bad sending unit? Cause the needle goes straight to the top when warming the truck.. Also could this be the reason why I have bad gas mileage only getting 16-18 mpg 201miles on 11 gallon tank?
Old 01-19-2012, 03:45 PM
peow130's Avatar
Well 16-18 is normal for a carbed 4 cyl motor. Your temp sender is probably junk. Toss it and buy a new one.
Old 01-20-2012, 07:49 AM
funcrazy1's Avatar
okay well sender is easy fix right just unbolt it, bolt the new one and plug the wire back in correct?
Old 01-20-2012, 12:43 PM
sixstringslut's Avatar
Dope the threads or you will be sorry.
Old 01-20-2012, 03:02 PM
peow130's Avatar
And in case you don't understand that jargon:
Wrap the theads in teflon tape.
Old 01-20-2012, 03:24 PM
funcrazy1's Avatar
so pretty much lock tight correct?
Old 01-25-2012, 07:57 AM
UPS
UPS's Avatar
Hope you didn't use locktite. poew130 meant plumbers white teflon tape. I think plumbers putty or "pipe dope" would be better or maybe even dielectric grease so the sender can make contact with the engine block. The sending unit varies the amount of ground or resistance to ground to tell the gauge what the engine temp is. If there is no contact between it and the block, there's no "ground" or total resistance = a cold/hot engine depending on how that sensor is setup.
Old 01-25-2012, 09:55 AM
funcrazy1's Avatar
Well i didn't use locktite I used Teflon tape
Old 01-25-2012, 10:03 AM
87Toy22r's Avatar
Your wire is grounding out some where. It's touching a metal part!!
Old 01-25-2012, 10:45 AM
CajunKenny's Avatar
I've heard that JB Weld is a good thread sealer.
Old 01-25-2012, 02:14 PM
funcrazy1's Avatar
I have fixed this issue it works no bad ground just bad sensor
yoterr
09-15-2015 03:47 PM
jacked_72
09-14-2015 03:31 PM
imhousing
09-10-2015 02:04 PM
anndel
09-10-2015 08:50 AM
LucasF249
09-08-2015 01:17 PM
Quick Reply: temperature gauge broke?
