Pre 84 Trucks 1st gen pickups
Strange idle problem 22r
Old 08-09-2013, 04:52 AM
Padawon's Avatar
So I have a 1982 22r completely rebuilt including the carburetor, Truck has been de-smogged and vacuum lines are hooked up like Canadian 1983 4x4 diagram.
I have something causing the engine to idle around 1200 rpms I originally set it for about 800rpms. It will intermittently drop back down to 800 RPM on occasion. When it does idle at the 1200rpm range… I cannot adjust the idle down via the idle screw, it will keep idling at 1200.
I notice that when I hit a good size bump on the road it will go back down to normal idle range setting 800rpm.
Old 08-09-2013, 04:54 AM
Padawon's Avatar
I got a can of starting fluid last night and sprayed around the manifold in hopes of finding a vacuum leak. I did not get any idle surging.
Old 08-09-2013, 05:38 AM
Stetson_md's Avatar
High/cold idle still intact and working right?
Old 08-09-2013, 06:52 AM
Padawon's Avatar
Guess Ill have to research that item and take a look.
Old 08-09-2013, 11:53 AM
83Toyota88's Avatar
That kind of sounds like something is getting stuck or hung up and then getting knocked loose on a bump. Might try to WD-40 all your carb linkage on the outside.
Old 08-09-2013, 12:13 PM
Padawon's Avatar
Thanks 83 Toyota.
Ill try that. I was thinking linkage issue as well but I couldn't find anything last night. a good spray job might loosen it up.
Old 08-09-2013, 12:22 PM
Staff
kawazx636's Avatar
Just curious, if your motor is desmogged then why do you have the vacuum lines ran like a Canadian model? The only vacuum lines you should have would be for the distributor advance and brake booster.
Old 08-10-2013, 06:21 PM
Padawon's Avatar
So it's the fast idle cam not disengaging....
Any way to adjust it to disengage?
The cam on my linkage does not look like the one in the Haynes manual, asin carb
Old 08-11-2013, 02:47 PM
83Toyota88's Avatar
Put a picture up
Old 08-12-2013, 05:23 AM
Padawon's Avatar
Old 08-12-2013, 05:51 AM
Padawon's Avatar
So if I tap on the linkage with my finger it will dis engage the Fast Idle, when I apply throttle the fast idle cam will re engage.
Old 08-12-2013, 06:50 AM
Stetson_md's Avatar
Is this thing moveing back whennit reengages
Old 08-12-2013, 08:28 AM
Padawon's Avatar
Im going to double check the Vacuum diaphragm tonight.
I notice the area in my red circle looks off??? I believe this was at the disengaged position.
Old 08-12-2013, 08:42 AM
83Toyota88's Avatar
Here is a couple shots of mine
Old 08-12-2013, 09:24 AM
Stetson_md's Avatar
Attachment 93790
Size:  808.2 KB nothing really jumps out as being off. But that peice works off gravity so if bumps affect when it engages and when it disengages that peice and the one on the throttle it catches are worth looking at
Old 08-12-2013, 09:33 AM
Padawon's Avatar
Ill lube those areas. It was working fine and now it has this issue.
I sprayed it down with some lubrication but maybe its binding. Ill see if they need a little bending and tweaking.
Old 08-12-2013, 10:03 AM
Stetson_md's Avatar
Might be the arm on the back of the diaphragm sticking inside the vac diaphragm I noticed there's a pretty good rub mark on this spare carb I got right where the arm and diaphragm come together probably wouldn't hurt to put some lube there twoName:  20130812_135412_zps7869056c.jpg
Old 08-12-2013, 12:07 PM
Padawon's Avatar
Yea I seen that and Im planning on getting that area.
Thanks for the pictures! Its hard to tell when its on the truck.
Old 08-12-2013, 12:44 PM
-Yoda-'s Avatar
I've been having this same problem for a while and have narrowed it down to the same areas....
About to undergo a frame swap so I am going to do some motor attention while I can get at it 360 degrees easily after the cab comes off.....
Let us know if you figure it out if like to know what it is
Old 08-13-2013, 03:42 AM
Padawon's Avatar
Its the BVSV, its not kicking on the vacuum to retract the choke diaphragm. I by passed it and applied manual vacuum (mouth) and it actuated properly. I checked the vacuum at the BVSV and it was no good. (1982 and down is a TVS instead of BVSV)
Now I need to hunt one down or by pass it some how. Dang I hate Electric choke carburators
Quick Reply: Strange idle problem 22r
