Pre 84 Trucks 1st gen pickups
Staring Issue
Old 05-01-2012, 02:03 PM
funcrazy1's Avatar
Staring Issue
so my truck has some starting issues sometimes... I put the key in the ignition to try to turn it on battery is fully charged cause everything turns on but when I try to crank the engine nothing happens not even a sound. Turn the key to start doesn't even try to start what could the issue be? It act's up sometimes I turn the key and bamn it goes
Old 05-01-2012, 03:57 PM
fishtruck28's Avatar
I know you have checked all the wires right? nothing loose not even a ground? Becouse we all know the gauges take a lot less amps than starting the motor. so that leaves us with not getting the right amps to the starting system. question to you is do you have an ohmetter or ammetter
Old 05-01-2012, 04:25 PM
Team420's Avatar
Have somone turn the key for u, and while they are turning the key, give the starter a couple good whacks with a steel pipe or something, does it start?
Old 05-01-2012, 06:33 PM
Staff
kawazx636's Avatar
Check to make sure your battery is putting out enough juice. Lights may come on, but the starter requires more amperage that lighting and other accessories. If the battery is good, check the connection on your starter. Check it's ground and it's feed with a meter. You can jump the starter by putting the ignition to the "on" position and take jumper cables directly to the starter. Attach your ground and tap it with the feed with the positive feed from your battery. It should start it right up if the starter is good.
If those seem to be good then your move on and check your ignition wiring for loose wires and grounds.
Old 05-05-2012, 06:45 AM
funcrazy1's Avatar
I went to Autozone they said its my Voltage Regulator had them test my starter altnertor and battery
Old 05-05-2012, 10:53 PM
Iceman92's Avatar
Did it work for you cuz mine is doing the same thing. Had the starter checked, it is all good.
bigjstang
08-25-2021 12:41 AM
nvdesertrunner
05-11-2020 08:18 PM
crammit442
7
11-29-2017 12:30 PM
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
Quick Reply: Staring Issue
