Pre 84 Trucks 1st gen pickups
shifter boot replacement
Old 04-08-2012, 10:05 PM
4serge's Avatar
Hi, is anyone replaced shifter boot ? Is it supposed to stretch over the thicker part of the lever or the lever can be unscrewed ? It seems that it will not go out without heating ..
Old 04-08-2012, 11:03 PM
wyoming9's Avatar
Red face
It just slides on from the top once you remove the knob.
I find some silicone spray helps it slide.:jessica:
Old 04-09-2012, 12:04 AM
4serge's Avatar
Thanks a lot ! Good that I asked. I smell exhaust fumes in the cabin and I think it is due to torn shift boot. From posts I found It seems new from dealer is more than $100 so I patched up the old one. I shall see if my repair will hold putting it on
Old 04-09-2012, 03:41 PM
bolink654's Avatar
New guy here (well, I've posted a time or two ages ago under another name, that I forgot the login details for)
My truck didn't have any shift boots when I got it. Just a plate of aluminum from were they cut the tunnel while putting in a 5spd. I had exhaust fumes in the cab too.
Bought some vinyl, needle & thread, some stainless screws and washers, used the aluminum plate from a previous owner and this is what I came up with.
Old 08-10-2013, 06:36 PM
83pickup-man's Avatar
i like the look. definitely custom.
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
BeMiceElf
10-10-2015 09:40 PM
Iceman4193
07-15-2015 04:48 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: shifter boot replacement
