Power Steering Conversion?
I have an 83 yota long bed with no power steering..Ive looked high and low on a this site and another and cant find anything on it although ive heard it can be done..id like to know how and what parts I need from what truck. thanks
Depends if you go with stock steering setup you need power steering pump and mounting brackets for engine plus steering gear and hoses from an 85 or earlier power steering equipped vehicle. But if you go with a high steer conversion you can use parts from an 86-95 IFS truck, which is better. http://www.marlincrawler.com/tech/gu...l-instructions
Look harder! It gets brought up all the time.
If you stick with push pull steering, then yeah, you need the reservoir, hoses, pump, steering box, belt pulley and mounting brackets from a solid front axle truck.
