Pre 84 Trucks 1st gen pickups
OEM oil filter or pure one?
Old 02-22-2009, 03:46 AM
X-AWDriver's Avatar
I've been using PureOne filters since '97 and they've done quite well on my very street and track abused turbo Eclipse and since I go 7-8k miles between changes on my 4Runner and it's working great I don't feel the need to try anything else cheaper or more expensive.
Here's a site where a guy cut all the filers open and gave his insights
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Here's a review of a Toyota filter (which I haven't seen anything bad about either)
Toyota 90915-YZZD1
This filter is manufactured by Denso and is rather unique. For starters, the cartridge has no end caps to speak of. Each pleat is thermally bonded shut at the ends about 3/16" inward. This was accounted for in the surface area measurement, however this filter still has the largest surface area out of the entire group: 160 sqin. The main reason for this is the narrow core tube, which allowed for very deep pleats and thus a very long filter element. A wide core tube is not needed for such a short filter. The filter does use a plastic bypass valve similar to the Fram filter, however I could not make this one leak. It is also held in place by a steel clip rather than plastic tabs like the Fram.
Old 02-22-2009, 05:29 AM
ozziesironmanoffroad's Avatar
Originally Posted by nico
Toyota filters have an anti-drainback valve in them. I don't know of any others that do.
Almost 600,000 miles on my 22R with OEM oil filters and Castrol oil. Good compression and power, and it passes CA smog no problem. I'm not about to change.
i believe the ones we use at work do too... ill look today... the shell filters...
Old 02-22-2009, 07:51 AM
95yoda's Avatar
most all the filters have a anti drain back. to the one guy, you have 600k on your 22R? holy crap!! so with 51k on mine I have about 500 years to go!
Old 02-22-2009, 06:11 PM
Island_Yota's Avatar
Wix makes the best filters, after that id say Napa Gold(made by Wix), Purolator(Pure one), a good Toyota one (Aka not a Toyota Thailand filter) is pretty good but Wix is probably cheaper, and the best you can buy.
Old 02-22-2009, 07:10 PM
  #25
95yoda's Avatar
How can you tell if you are getting a good or bad toyota filter?
so why would you rate the napa gold and pure one better then the yota one? I have heard that as well, just wanted your take.
Old 02-23-2009, 04:56 AM
  #26
X-AWDriver's Avatar
From the link I posted it seems Fram filters are the ones to avoid.
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
horunner1x
07-10-2015 06:33 AM
Quick Reply: OEM oil filter or pure one?
