OEM oil filter or pure one?
Is the stock toyota filter good? I read it has cardboard inside like frams do? true or false? the previous owner used toyota because I looked, its blue with white writing. I was thinking of a purolator pure one? who knows about this? thanks.
so no one knows about the cardboard inside? someone cut a corolla filter open and it was the cardboard kind. if thats the case im going with a pure one. no cardboard.
shows nothing to substantiate your cardboard claims on Toyota oil filters...other brands perhaps.
Are you serious? it took less then a second on google to see toyota indeed does use cardboard end caps. glad I researched it, I will be using a pure one it looks like. no cardboard for me.
I cant post it as im on my phone. but I typed in "cardboard toyota oil filter" in google and there were subjects about it on other forums and such stating they use cardboard in the filters. ive heard nothing but good stuff about the pure ones.
Wabbit already pointed out that they were Fiberglass, i didn't feel the need to do so.
http://www.corolland.com/oil-filters.html
Read that through. And while the article writer states "paper" he is only sort of correct, its fiber reinforced paper.
From the link you posted.........
This filter had cardboard end caps glued to each end of the filter element (I found this disappointing quite frankly).
I read this in a few links iv seen now.
one toyota filter did not even use end caps.
I guess I dont see why its so great? just because its stamped with the toyota name does not mean its touched by the hand of god lol.
I dunno, the others with metel seem more sturdy.
If you don't like the cardboard, don't use it.
But it is just an oil filter, not a u-joint, so I don't think "metal" end caps make a hill of beans difference since that does NONE of the filtering.
The FILTER media is what is important.
It's an oil filter that has a known reputation to work extremely well and has a unique design.
the dealer was like thats a clean truck, wanna trade it in on a new one? he was talking about my 82. I laughed and said the old one is built way better and is not a overgrown pig like the new taco lmao.
the dealer wants 5.50 for the filter. grrr
I have an 85 4Runner, 85 ext cab, 87 4Runner, 97 4Runner (rolled), 07 4Runner and an 08 Tundra (and I've owned probably at least a half dozen or more Toyotas) and I will never own anything but a Toyota.
Yep, they don't make them like they used to but I still love my Toyotas.
Buy you a case of oil filters from trdparts4u.com or somewhere like that and get them for under $3 each. For me that might last me a year with all the Toyotas that go through here, mostly 22R/REs all using the same oil filter.
Next time I dispose of one I'll cut it open for giggles and post the pics for kicks.
do the front and rear diffs on the 82's have drainplugs to drain the fluid? and what should I put in the diffs and transfer case? is it like 80-90w gear oil in all 3? or?
thanks.
I'm far from guru status, but I did stay at a Holiday Inn Express last night. As far as I know they have drain plugs on the bottom and fill plugs on the ends just like all the other 79-85 Toyota SF axles/diffs do. I don't think I have ever actually worked on an 82 SFA. I put synthetic RP 75w90 in all my diffs/5spd/tcase.
Toyota filters have an anti-drainback valve in them. I don't know of any others that do.
Almost 600,000 miles on my 22R with OEM oil filters and Castrol oil. Good compression and power, and it passes CA smog no problem. I'm not about to change.
i've been using either toyota or fram oil filters on my rigs, havent' had a one problem at all. Toyota filters for my toyota and fram for the other rigs i have. And i'm sure toyota's been around the block a few times and know what they are doing. I have full confidence in my "cardboard" toyota filters. Oh and toyota should put on that grip material like fram does. It would make is sooooo much easier to grip.
