Pre 84 Trucks 1st gen pickups
L52 Shift Lever removal
Old 04-05-2009, 06:12 PM
Fossilized
Staff
dropzone's Avatar
OK, my stupid 10 minute job to replace my worn shift bushing (ordered 1.5 years ago and finally found it stashed in a tool box drawer) is turning in a job.
been letting it soak for awhile:
Manual says to use SST 09305-20012 that looks like you apply pressure downward and turn counter clockwise at the same time to remove a kind of dome shaped retainer to remove the shift lever:
I don't have one of these handy doodads...I have tried tapping it down with a punch lightly with a hammer.
anybody got an alternate method that will prevent me from hammering and destroying this thing?
I though about removing the shift lever retainer housing (4 bolts from underneath) but am not sure if that will cause further issues...
thanks guys
Old 04-05-2009, 06:15 PM
Staff
DeathCougar's Avatar
We just use our fingers at work, and it seems to work ok. MOST of the time.
However, we do run into problematic retainters on occasion at work, and usually a couple of screw drivers works just fine. You need to press down, and turn counter clock wise about 20 degrees or so, then the retainer will pop up above the housing, and the shifter will pop out.
Old 04-05-2009, 06:16 PM
yotaboy82's Avatar
all i did was push down with my hands and turn
Old 04-05-2009, 07:03 PM
Fossilized
Staff
dropzone's Avatar
I am thinking it is probably a little rusted...I will give it another shot of PB blaster before I go to bed and see it I can pop it out in the morning...thanks
Old 11-15-2014, 02:26 AM
Fossilized
Staff
dropzone's Avatar
OK, ancient thread but i thought i would update this thing with what I made a month or so after posting this thread
Originally Posted by dropzone
Poor Man's shift lever retainer removal tool:
here is a pic out of the manual that shows the SST:
since i had the idea of using an old socket or some tubing I thought I would give it a shot. 6 minutes with the grinder I had this:
1" square tubing, notched and bent in slightly to fit in the shifter retainer
slip it over the shift lever
use your tool of choice, push down and turn to the left about a 1/4 turn
bingo:
Old 11-15-2014, 07:03 AM
gillesdetrail's Avatar
About time
Good info, would be easier on the fingers.
Old 11-15-2014, 09:09 PM
Staff
kawazx636's Avatar
I feel like it is my duty to buy you a new pair of channel locks for Christmas after seeing the ones you're working with!
By the way, I can remove my retainer with my bare hands; no tools at all!! Just felt like bragging there.... LOL
Old 11-18-2014, 03:37 PM
Thelast83inNJ's Avatar
I took a large pair of reversible snap ring pliers ground a notch on the outside of each leg. Push and twist
Liadrin
04-25-2022 02:54 PM
okamikai
04-30-2018 10:19 PM
mskalmus
05-28-2017 07:51 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: L52 Shift Lever removal
