Pre 84 Trucks 1st gen pickups
L43 transmission goes bye bye
Old 06-17-2011, 06:44 PM
toyotacharles's Avatar
Question L43 transmission goes bye bye
79 short bed 4x4 22r transplated but the dam L43 trans went out in 3 months, want to replace but with low buget and almost no fab available. looking at transmissions from L50 or L52 would like to even go for g series or r series but length seems to be issue and need replace t-case to fit as well, need lines for parts aquirement and for ideas if fab is involved. i know shafts will need be moded if g or r series installed and flanges for front and rear diffs need replacing. the shafts i can get and have moded locally but the trans is proving hard to find.
The following users liked this post:
Powell (06-02-2019)
Old 06-17-2011, 09:48 PM
Fossilized
Staff
dropzone's Avatar
parts souce sticky at the top of a lot of the folders:
https://www.yotatech.com/forums/f114...rs-etc-221643/
you will need to move the crossmember back
L52/L50 go in with out any extra mods...
Old 06-19-2011, 07:53 PM
since the l43 trans is a converted/modified 2wd trans would it be possible to mod a different 2wd trans to 4wd? L45? L50? Has anyone tryied this?
TheBFA
02-15-2020 06:55 AM
Pri$erulz
11-17-2019 08:03 PM
Odin
09-26-2015 06:56 PM
toyotasaurus
09-24-2015 03:30 PM
briholt
09-20-2015 10:26 PM
Quick Reply: L43 transmission goes bye bye
