Pre 84 Trucks 1st gen pickups
L43 4 speed shifter issue
Old 07-31-2012, 01:06 PM
enigmaT120's Avatar
Originally Posted by CAdot
it will be here tomorrow and i'll update with part number to save someone else the trouble. probably not many L43's in use tho, but who knows...
That's what I'm running, I think. The stock 4 speed in my '81? Mine kicks out of 3rd gear, and very rarely 4th, when I let off the gas, but I just work around it for now.
Old 07-31-2012, 06:42 PM
CAdot's Avatar
Old 07-31-2012, 06:59 PM
CAdot's Avatar
Old 07-31-2012, 07:03 PM
CAdot's Avatar
Old 07-31-2012, 09:29 PM
  #25
humboldthilux's Avatar
Does anyone know what the set screw on the bottom of the side case does on one of these transmissions, there is a screw with a slot for a flathead and a retaining nut to tighten it for some kind of adjustment inside, here's why im asking, https://www.yotatech.com/forums/f131...t-work-256877/
Old 10-02-2013, 03:20 PM
  #26
Finnegan's Avatar
I'm bumping this thread instead of starting my own because I didn't take enough pictures for a complete write up on the bushing swap, so I'll threadjack this one since this was the most helpful thread I found. For the L43 you need (4) PN# 33615-20021 rubber bushings for the transmission mount of the shifter ball joint and (1) PN# 33548-20010 shift lever bushing. Its a super simple repair, you unscrew the four screws holding the shift boot plate, then undo the two bolts holding on the shift lever ball joint and the entire assembly just pulls through.
Those are the two bolts holding on the shift lever ball joint and assembly, you can see in these two pictures how much play I had.
Once that's out, you clean it up and remove the remnants of the shift lever bushing from the end of the shift lever. This is all that was left of mine.
Then you clean everything and re-coat everything in grease and reverse install it. I was surprised at how simple the whole thing was, and it makes a HUGE difference; I can finally tell I'm upshifting from 3rd into 4th and not from 3rd into 2nd or reverse. You can see the amount of play I had in neutral before and after.
Before:
After:
And this is all the slop I have in 3rd (I forgot to take a before picture):
The following users liked this post:
ViewSeeker (01-31-2023)
Old 06-13-2014, 06:59 AM
  #27
tumolt's Avatar
Got bushing from Crawler for my L43 Would like to know procedure in which I can replace it without using a so called professional. Thanks, Matt P.S. Is there a link on replacing this with a 5 speed tranny?
Old 06-13-2014, 07:05 AM
  #28
tumolt's Avatar
Where do the rubber bushings go? Marlin sent me only 1 and you said I need 3 more which I will order. But where do they go? Thanks, Matt
Old 07-20-2014, 10:48 PM
  #29
Finnegan's Avatar
Oh man, I am SO sorry Matt, I got super busy and I never got any notifications that anybody posted in this thread. So the four soft rubber bushings go on either side of the bracket that the shifter is mounted into. So it should go transmission*bushing*shiftermount*bushing*bolt. You can see it in this photo.
Again, I'm sorry and I hope you got it fixed on your own. I got hit by the life freight train.
Old 07-21-2014, 05:21 AM
  #30
CAdot's Avatar
Old 06-04-2015, 06:12 PM
  #31
Smoky80/81's Avatar
How's it going everyone. I believe I have the L43 transmission. It's a 4 speed with the shifter off to the side... I can't seem to locate the Back-up switch on the transmission. Can anyone point me in the right direction?
Old 06-06-2015, 07:52 PM
  #32
msane99's Avatar
Passenger side. Right behind shifter i think. You dont have to dig, its visible from passenger side.
Old 06-07-2015, 04:48 PM
  #33
Smoky80/81's Avatar
I found one switch in that general area but I confirmed that is actually for my 4WD indicator. Is it more towards the rear?
Thanks
Old 06-24-2015, 01:41 AM
  #34
msane99's Avatar
one on transfer case is 4wd indicator. one on transmission is backup lights
Alex Bessinger
08-31-2015 09:17 AM
kyletbert
07-17-2015 11:39 AM
Iceman4193
07-15-2015 04:48 PM
crashburnoveride
07-10-2015 06:39 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: L43 4 speed shifter issue
