Pre 84 Trucks 1st gen pickups
knock in top end/ valve clearance??
Old 03-29-2013, 05:05 PM
catfish21's Avatar
Hey all today I did some work on my truck and pulled the valve cover and was going to attempt to change my valve seal, well I pulled the head bolts and made spacers to bolt it back down to put compressed air to hold the cylinder up well it didn't hold pressure so I pulled out and bolted everything back up. I also added the LC spiral adapter to my weber today but when I got everything back togethwr and started her up she had a pretty bad knock in the top end coming from the valves I'm guessing could this.be that my valve clearance is off now making it sound like that or what I didn't ajust the valves at all so any info would be great and it did not sound like this at all before I did this job thanks
1982 Toyota pickup 4x4
Old 03-29-2013, 05:49 PM
83's Avatar
You pulled the head bolts?...
If you overtightened the valve cover bolts, the rocker arms may be hitting the top of the valve cover. They don't need to be very tight at all.
Old 03-29-2013, 05:58 PM
catfish21's Avatar
Yeah you have to pull the head bolts to get the rocker arm assembly off so I made spacers to bolts the head back down to try and change the valve seals by pitting compressed air in the spark plug hole well it didn't hold pressure so I just bolted everything back up now it has a valve knock its in the top end for sure I'm just trying to find out what this is I guess I'm gonna try tomorrow and adjust the valves could that be the issue or what and like you said it mite be the cover to tight I don't know thanks for the help and any info will be great I hate this knock now
Old 03-30-2013, 06:24 AM
Staff
kawazx636's Avatar
FYI, the compressed air valve seal trick NEVER works on a 30+ year old truck. Typically the spring keepers are seized to the valve and impossible to remove on the truck or the valve seats are worn so it doesn't seal enough to hold the valve up with compressed air. IF you do manage to get the spring and old seal out then the chances of getting the new seal, spring and keepers back on without hearing the "clink" of the valve hitting your piston because you lost the compression that was holding it up are slim to none! Buy a head gasket and do it the right way.
As far as your knock, loosen the bolts on your valve cover. You most likely torqued it down too far and your rocker arms are tapping your valve cover.
Old 03-30-2013, 07:19 AM
catfish21's Avatar
Well today I'm gonna warm the truck up and pull the valve cover and adjust the valves and I want pit the valve cover back on so tight and I will have an update thanks for the info
Old 03-30-2013, 07:51 AM
cman1's Avatar
finger tight plus a quarter to half turn with fibg on the half moons.
Old 03-30-2013, 08:10 AM
catfish21's Avatar
So that is all I tightened the valve cover that don't seem like much
Old 03-30-2013, 08:37 AM
cman1's Avatar
I think the manual calls out 12 inch pounds,the finger tight plus method has always worked for me.it will make a lot of noise when overtightened...which a lot of people fall victim to.
Old 03-30-2013, 09:44 AM
catfish21's Avatar
My service manual says something like 9 ft pounds so Idk but I'm bout to try it can the valve clearance be off making a noise also
Old 03-30-2013, 10:35 AM
cman1's Avatar
I wouldn't say all of a sudden, start it up,back off the valve cover bolts a little at a time,if it goes away...easy fix!!!
Old 03-30-2013, 01:12 PM
catfish21's Avatar
Well I want to say thanks again everyone Yall are the best at knowing these ol yotas I let her warm up pulled the cover adjusted my valves to spec and just snugged the cover up and she is running like a dream now no oil leak or nothing and the new spiral adapter I put on for my weber is awesome thanks again everyone the yota rides on
Old 03-30-2013, 04:18 PM
cman1's Avatar
awesome!!!
Old 04-03-2013, 08:57 PM
Staff
kawazx636's Avatar
We tend to know a thing or two about toyotas around these parts...primarily because we've all at some point in time made the same mistakes! LOL
Old 04-10-2013, 04:30 PM
catfish21's Avatar
Ok so a new question again today I noticed when I started it it knocked in the top end for like three seconds and went away and it does it if I turn it off and wait 16 minutes and start it again it does it again for just a second then runs fine. It sounds like when you change your oil and you start it for the first time till the oil circulates then goes away, it hasn't done this before so I'm hoping it don't have anything to do with when I tried to change the seals, what do you guys think this is and is all that bad or what I mean it is 32 years old but any info would be helpfull
Old 04-10-2013, 05:26 PM
Staff
kawazx636's Avatar
what kind of oil filter do you use?
Old 04-11-2013, 01:36 AM
catfish21's Avatar
I have a Toyota oil filter and Toyota oil and changed it when I did that work to it I just hope this isn't something bad coming on, now I did do something different and put a quart of Lucas in it but I don't think that would be the reason but I have no clue
bigjstang
08-25-2021 12:41 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
calderp
07-27-2015 09:58 AM
keithporter83
07-18-2015 12:37 PM
Quick Reply: knock in top end/ valve clearance??
