i have some problems.......79-no power
Ok, i have a 4x4 79 toy with a 20r and 4speed, i drove it last weekend, everything was working as it should. I go out to start it today and i have nothing, no lights didnt even try to turn over or anything. I have power down to the starter, all the fuses are good. WHATS WRONG WITH MY BABY!!!
So you have power to the starter so it's obviously not the battery. and I'm thinking it's something other than the starter solenoid or you would have your lights and accessories. I'd start by checking the commong point in the system...the ignition switch. If you're not getting anything when you turn the key to 'acc' or any other position I'd start tracing things back from there and see if you've got a bad connection, maybe on your main power coming up to the ignition switch. Check your fuses and relays before you do anything though....sometimes it's the easiest fixes that are hardest to find. Let me know how it goes.
If fuses and battery are good, you should be able to turn on markers and headlights.
Did you measure voltage to the starter on the very thick wire that goes
directly to the battery? Did you use a volt-meter? How many volts did you see? it might be no load voltage (i.e., you're not cranking the starter).
Checked the voltage on battery?
Checked voltage on battery when you turn the accessories on?
Voltage on battery when you turn on the lights?
If voltage goes too low when you turn on lights or try to start, battery maybe discharged.
If you find nothing after all of the above, check FSM (link on my signature)
I am going to pick up a volt meter tomorrow. All of my fuses are good, I cleaned all the ground wires. Could the volt regulator cause a problem like this? I thank you all for the help
Yes, agree with checking fuses, especially the large ones in engine compartment.
delmert
09-30-2015 04:34 PM
