Pre 84 Trucks 1st gen pickups
how to tear into the L52 transmission
Old 01-03-2017, 06:31 PM
ckzdaj6's Avatar
what puller
Did anyone answer which puller to use? So a l42 input shaft will work on a l52?
Old 01-03-2017, 08:54 PM
gillesdetrail's Avatar
Originally Posted by msane99
Hey bud how did you end up getting these bearing out? I'm in the same spot. Need to know what puller to buy without spending a fortune on a bad arse snap on set.
There are some decent videos on youtube for ford top loader 5speeds. the mechanics are the same from what I can tell.
I ended up modifying a generic puller by grinding down the shafts to make them thinner so they would fit inside the case and grab the bearing by the back, it worked!
My L45 input shaft fits in my L52, I got a bigger bearing for it and had it pressed on. Not sure about the L42 input shaft, only if it is the same as L45.
Old 11-19-2020, 07:44 AM
SMG
SMG's Avatar
How hard of a job is this for your average mechanic? I'm debating on tearing into my L52.
Thanks?
Old 01-09-2022, 10:05 AM
INFINITY's Avatar
Sorry
Sorry I haven't been on here in years. As I remember it wasn't too complicated. But it was more of trying to figure out a puzzle than anything. Just pulling everything apart and laying it in a way that I can put it back in exactly the same. I sold one of my project Toyotas and gave them all the extra parts I had for this transmission about 2 years ago.
London84T
08-23-2017 01:19 PM
sweitzerworks
07-07-2016 01:19 PM
TruckeeToy
01-07-2011 07:32 PM
slothman
12-18-2008 11:13 AM
Quick Reply: how to tear into the L52 transmission
