How to get fuel gauge working again on 82 Toyota pickup??
I was doing an axle swap on my 82 Toyota pickup so it wasn't driven for about 4 months. The fuel gauge that worked before now shows "empty" even though there is 6 gallons of gas in the tank. The fuse is good. Could someone share the steps on how to diagnose this please?
Thank you.
Thank you.
Located the wires that's connected to the fuel sender unit. Ground it out and see if gauge moves. If gauge moves then sender is bad. If gauge don't move you have a wiring issue.
If grounding it out doesn't move gauge try adding bolts to it. One or the other makes it move. Can't quiet remember which
My sender was glued at half by evaporated fuel gunk when I bought my truck. A couple tankfulls with Seafoam added loosened it up right away.
If your truck has sat for a while, you could have a similar situation.
Staff
Here is how I cleaned/fixed mine. Just need to get the pivot point area cleaned up.
The other day I was working on getting my fuel level sending unit freed up. I use a rust dissolver on it and a wire tooth brush. It moves freely now.
This stuff works great.
Float level I was working on, this is most likely your problem if fuel guage isnt working. Easy fix, once you get the bed off or on a runner, you have to drop the tank as it is located behind the acess panel.
Does the "sender" pivot inside the gas tank kind of like the float in a toilet tank? And should I assume that the pivot point is at the top of the gas tank? Once the tank is removed, how easy or difficult is it to remove?
Thanks
Thanks
Staff
Just below my thumb. It is inside the gas tank. You can see the piviot pin on the righ hand side of the two rods. This is for a fuel injected motor but the floats are nearly the same.
I don't understand what you mean when you said to try adding bolts to it?
Can I remove the sender without having to remove the gas thats in the tank?
Thanks again.
Thanks again.
red88toy
11
08-03-2015 07:47 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
