Pre 84 Trucks 1st gen pickups
HELP! Need to make wiring harness for 22re in 83 pickup
Old 01-08-2013, 09:03 PM
keenan lukacs's Avatar
I have a 1983 short box pickup. I was running a 22r with a weber carb and a small cam. But it seems that my 35"s with factory 4:10s was too hard on the engine. Anyway, i ended up with a really bad rod knock and decided it needed a rebuild I bought a 87 4runner with a freshly rebuilt 22re, auto. I bought the 4runner cheep so that i could put the 22re in my pickup that is already mostly build the way i want it. The 22re is now in my truck with everything complete besides the dash wiring and gas tank swap. I am looking for some help with the dash wiring. I would like to keep as much of the wiring that is factory in the truck as possible. If anyone else has any experience with this swap it would be a lot of help if you could share what dash wires you had to swap into the truck and what you were able to completely remove. I would like to have as little unused wires in my truck as possible.
Thanks
Old 01-08-2013, 09:06 PM
I have a 1983 short box pickup. I was running a 22r with a weber carb and a small cam. But it seems that my 35"s with factory 4:10s was too hard on the engine. Anyway, i ended up with a really bad rod knock and decided it needed a rebuild I bought a 87 4runner with a freshly rebuilt 22re, auto. I bought the 4runner cheep so that i could put the 22re in my pickup that is already mostly build the way i want it. The 22re is now in my truck with everything complete besides the dash wiring and gas tank swap. I am looking for some help with the dash wiring. I would like to keep as much of the wiring that is factory in the truck as possible. If anyone else has any experience with this swap it would be a lot of help if you could share what dash wires you had to swap into the truck and what you were able to completely remove. I would like to have as little unused wires in my truck as possible. This is my daily driver, need it back on the road soon!
Thanks
Attached Thumbnails HELP! Need to make wiring harness for 22re in 83 pickup-image-1228775268.jpg
Old 01-08-2013, 09:10 PM
Fossilized
Staff
dropzone's Avatar
Dude please quit creating multiple threads on the same subject. This is the 4th one
Old 01-08-2013, 09:17 PM
Sorry about that, computer said that they were not being posted because they was already a thread with that title. So i changed the name and tried to post it again. Then they all worked
Old 01-10-2013, 07:37 PM
Anyone? I know theres people that have done this swap. I just have not been able to find anything on how to wire it.
Old 01-10-2013, 08:22 PM
wyoming9's Avatar
Red face
What you need to do is locate the electrical manual for your truck and the year of your engine.
Then you need to sit down look what you need to merge into the truck harness and what is no longer of any use.
I really doubt anyone has keep a wire by wire record of how this was done but you might get lucky.
Old 01-10-2013, 09:14 PM
Fossilized
Staff
dropzone's Avatar
Thread Link should give you some help
Old 01-11-2013, 02:52 AM
suncomb1's Avatar
You need the electrical diagrams for you truck and for the donor vehicle. You will have to sit down and draw yourself a new electrical diagram that incorporates the features you want or need from both. Once you have done that, you need to look at your wire harness routing, the type of electrical plugs / connectors you need, etc. All this takes time but when you are done (if you do it right) you will have a trouble free installation almost like it came from the factory. Do not splice wires, use wiring butt connectors or wire nuts.
Old 01-11-2013, 07:03 AM
JustDSM's Avatar
Forgive me for being the pessimist, but if you're asking these questions you really are not prepared to undertake the task at hand and complete it properly. Seek out someone who has the knowledge and or background to help you along this project. That would be my advice.
Old 01-11-2013, 07:21 AM
toastyjosh's Avatar
Dude, search is your friend!
Check this dude out, read all 4 pages.
http://toyotatrekker.proboards.com/i...play&thread=55
For this much work I would be going with a 2or 3rz.
Good luck!
Old 01-11-2013, 12:03 PM
Thanks for the links guys. The one on pirate showed me exactly what i needed. I did the tank and fuel line swap just a couple minutes ago. Ill start the wiring tonight. Hopefully have it running again soon
Also got some different 4:88 thirds. Both have posi-track
Old 01-11-2013, 12:52 PM
toastyjosh's Avatar
Dont forget to show us when your done!
Old 01-11-2013, 01:01 PM
Ill be sure to do that. Is posting a video as simple as posting a picture? Or does it have to be a youtube link?
Old 01-11-2013, 01:05 PM
toastyjosh's Avatar
yea both will work.
Old 01-13-2013, 11:53 AM
Got my ecu mounted. Simple to remove, only one bolt holds it in place
Attached Thumbnails HELP! Need to make wiring harness for 22re in 83 pickup-image-1634454384.jpg   HELP! Need to make wiring harness for 22re in 83 pickup-image-255214318.jpg   HELP! Need to make wiring harness for 22re in 83 pickup-image-3382556986.jpg
Old 02-25-2013, 08:35 PM
It runs! I have to do the timing chain guides but currently have an lce timing chain kit with metal guides on the way. All the dash is back together and everthing works like its supposed to. I also added a check engine light to the factory instrument cluster.
Attached Thumbnails HELP! Need to make wiring harness for 22re in 83 pickup-image-4047302242.jpg   HELP! Need to make wiring harness for 22re in 83 pickup-image-2498067305.jpg
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
Yota.Jay
03-06-2016 11:02 PM
quaale94TRD
3.4 Swaps
06-23-2015 10:27 AM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: HELP! Need to make wiring harness for 22re in 83 pickup
