Pre 84 Trucks 1st gen pickups
Has anyone successfully rebuilt a stock 20R carb?
Old 12-30-2013, 05:46 AM
Zack1978's Avatar
Hi everyone,
The carb on my 1979 4x4 short bed is in need of a good cleaning and rebuilding. The truck runs ok, but the exhaust is a bit much and I'm sure it's gummed up from sitting.
I looked on Rockauto and I can get the rebuild kit quickly for a relatively low cost. So how hard is the job? I have never touched a carb, it is completely new territory for me. Are there steps/instructions someplace?
I called a local carb shop and he wants between $250 and $300 to rebuilt the carb. I can also get one from National Carb for about $160. Is this a job that I should just pay for and not even mess with it?
Also is there a 20r carb guru that rebuilds them?
Thanks,
Zack
Old 12-30-2013, 06:18 AM
83's Avatar
I got mine from National.
Whether you should attempt it yourself is up to you...what's your skill level? It can be done. But it's a lot of small parts.
Old 12-30-2013, 06:59 AM
83Toyota88's Avatar
2nd the option with the national carb. Lot of people have good things to say about them.
Old 12-30-2013, 08:36 AM
83's Avatar
To be totally clear, I can't speak to the quality of National yet. I installed the carb, but I had a leak at the base (issue with my spacer and gasket, not the carb), and put some gasket-maker (FIPG) on there, then it got cold...and I haven't found the time yet to get back out there and see if the leak is gone.
So until my vacuum leak is taken care of, I can't comment on how the carb works.
Old 12-31-2013, 05:29 AM
81 Toyo's Avatar
I've said it before but I had good experience with National after trying to rebuild it myself. For the money I think its the way to go, they are all bench tested and set to factory specs so its a "bolt on and go" situation. That being said try rebuilding it yourself first, the kit should come with instructions and it may just work, you can always get a rebuilt if it doesn't.
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
tomczaksdiesel
07-26-2015 10:35 PM
80Truck
07-24-2015 03:12 PM
Quick Reply: Has anyone successfully rebuilt a stock 20R carb?
