Pre 84 Trucks 1st gen pickups
Fuse box replacment.
Old 11-21-2012, 03:06 PM
Rollz79's Avatar
I need to replace the fuse box in my 79. Truck had a leaky front window water has made the fuse box good bad. I've done some searching
Dose anyone make a OE style replacement? I was think about buy a fuse box like this.
http://www.ebay.com/itm/12-Position-...807482&vxp=mtr
Any input would be very thankful.
Old 11-21-2012, 04:32 PM
slacker's Avatar
I have a stock one you can have ... you just pay freight
Old 11-21-2012, 09:11 PM
UPS
UPS's Avatar
I swapped the glass tube fuse panel from my 1980 for one with the plastic blade fuses from a junkyard donor. I think it was a 1982. I did one circuit at a time and spent a lot of time with the Clymer and Chilton wire diagrams. The newer fuse box has some minor differences from the older one, but I was able to have 2 more fuses to play with. I was kind of a pain to do but I'm glad I did.
Old 11-21-2012, 09:41 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by Rollz79
the 82-83 style would be nice. the one you mentioned on ebay doesn't even look like it has the needed terminals. i hate the glass fuses.
rewiring the box will be a pain..i would solder and heat shrink each connection. that many quick connects will be bulky and most likely one will get fubarred
Old 11-21-2012, 09:57 PM
UPS
UPS's Avatar
Soldering is the way to go. That's why it was a pain, on my knees half in half out of the truck. It only took about an hour to instal. Another good thing is it bolts right under the dash.
Old 11-22-2012, 01:02 AM
wyoming9's Avatar
Red face
Just what is wrong with yours that it can`t be fixed cleaned what ever etc.
Have you since repaired the leak so you are not in the same condition after a few good rains.:wabbit2:
Old 11-22-2012, 03:18 PM
Rollz79's Avatar
PM sent
Old 11-22-2012, 03:25 PM
Rollz79's Avatar
I have fixed the leaking window. The problem is that the fingers that hold the glass fuse in have broken over the years. you have to get the fuse in there just right for it to work.
Old 11-25-2012, 05:20 PM
Pumpkinyota's Avatar
I bit the bullet and rewired the whole truck using a painless 18 circuit offroad kit. It was not by any means "painless" (and I have a fair amount of experience, as well as the proper tools), but it has been incredibly rewarding in the end. My lights are brighter, everything works properly, and I got to cut out years worth of electrical hack jobs.
choppe777
05-16-2016 08:00 AM
Gone Fission
09-04-2015 12:18 PM
Aaron Logan
09-03-2015 08:08 AM
39 Thieves
08-31-2015 12:51 PM
Mrhoadley
08-04-2015 06:08 PM
Quick Reply: Fuse box replacment.
