Pre 84 Trucks 1st gen pickups
Fuel Idle Cut Solenoid
Old 01-14-2011, 07:41 AM
C17loadclear's Avatar
Can someone please post a pic of the fuel idle cut solenoid. My book says Cali trucks didnt come with one and I want to see what it actually looks like.
Thanks
Old 01-14-2011, 08:03 AM
xxxtreme22r's Avatar
what book is that? My "book" says this:
VALVE, SOLENOID
21347-35420 Replaced by: 21347-35510 1986.08-1987.08 22R.. RN5#.. USA
Manufacture notes: CALIFORNIA SPEC
Old 01-14-2011, 08:08 AM
coryc85's Avatar
Here is one I removed from my '83 pickup, which BTW, I bought in California. Not sure if it was originally a Cali truck or not:
Old 01-14-2011, 08:14 AM
hey coryc85, I don't have mine any longer, but do you remember at the end of that having a removable jet like the weber idle solenoids?
Old 01-14-2011, 08:31 AM
coryc85's Avatar
xtreme - I don't think anything is removeable on this thing except for that little o-ring on the tip. Of course, I could be wrong.
Old 01-14-2011, 11:42 AM
My Hanyes manual says Cali exempt in the wiring diagram. Thanks for posting a pic. I dont have anything like that on my carb. I do have a solenoid on the passenger front side but it does not look like that. It has a spring with a rubber washer on it.
This is a factory truck with no mods as it was my dads (I learned to drive with this truck)
It is a 1981 SR5.This thing is driving me crazy trying to figure out the idle problem.
Old 01-14-2011, 11:47 AM
I will check what toyotapartszone says on the 81 the one I checked you can see the years the cali spec included.
The solenoid you describe sounds like the outer vent solenoid. As I don't believe there is any other sol. on the carb.
Old 01-14-2011, 01:34 PM
83's Avatar
If I remember correctly, the idle fuel cut solenoid is on the passenger side rear of the carb. So if you've got nothing there, then yeah, you must not have one. It is a "common" cause of stalling on these trucks though, even with rebuilt carbs.
Old 01-15-2011, 04:23 AM
I have read the trouble with rebuilding and was wondering if anyone has bought a reman carb from someplace and had good luck with it...If not, I guess I will go the way of the weber.
Of course, then I have to deal with all the emissions stuff.
Old 01-18-2011, 11:08 AM
83's Avatar
I bought a rebuilt carb. It's works great...except for the idle cut solenoid going bad
They don't replace that part in the rebuild.
Old 01-26-2011, 08:03 AM
Soon's Avatar
Did you ever solve the problem? I had an idle problem and thought it was the fuel cut solenoid and it turned out to be the EGR valve.
Old 01-26-2011, 02:18 PM
Smile
Hey Guys,
Sorry to have not posted sooner...The problem was the solenoid but I think the EGR is bad also as it doesnt pass the vaccum test. The truck is idling a little rough but at least it is running all the time now. I am thinking about blocking it off rather than fork out 200 bucks. Whatcha think?
Thanks for all the help.
Todd
Old 01-27-2011, 04:59 AM
Soon's Avatar
I put a little bolt into the vacuum line to the EGR valve which effectively blocked it off and its been running perfectly ever since.
Old 01-27-2011, 11:37 AM
83's Avatar
I just plugged all the egr lines with golf tees. Someday I'll make a blockoff plate. The EGR is probabaly a good thing when functioning properly. But in trucks this old, they're pretty much never functioning properly, and the easiest most cost effective fix is just blocking them off.
Old 04-11-2014, 08:25 AM
esievel's Avatar
fuel cutoff solenoid
I just had my first experience with this solenoid. Didn't realize this would be on a non fuel injected vehicle. I was given a jump by someone who accidentally crossed the connection. It blew the fuses of everything that comes on with the ignition. I couldn't keep an idle. Fortunately I found a thread on this forum that lead me to the issue. Nice simple fix.
Old 09-30-2014, 01:11 PM
Ange5583's Avatar
Hi
Last weekend my son jumped incorrectly and damaged the Alternator, replaced it but now engine wont idle. How did you repair your solenoid not working?
Old 09-30-2014, 03:31 PM
esievel's Avatar
fix for fuel solenoid
A fuse. I don't recall what it was listed as but it was a fuse.
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
v_man
07-23-2015 04:01 PM
Fundy Rider
07-16-2015 01:35 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Fuel Idle Cut Solenoid
