Pre 84 Trucks 1st gen pickups
Failed Smog - Gross Polluter - Now What?
Old 07-11-2011, 12:20 PM
bonsai4rnr's Avatar
smog
let me start out by saying i apologize for high jacking this thread. I am brand new on Yotatech and they wont let me start my own thread untill I post 15 times on someone elses thread. I have a 95 runner 3.0 and it wont produce enough power to pass the smog test, when it is timed correctly. I currently keep it timed 7 degrees advanced and it runs great. I was thinking maybe the timing belt was worn, any suggestions. Again I apologize for the high jacking
Old 07-11-2011, 04:56 PM
ToyoTech559's Avatar
what do you mean not producing enough power? stock timing is 10 degrees
Old 07-11-2011, 08:21 PM
bonsai4rnr's Avatar
smog
so i keep it at 17 degrees (7 degrees past) and yes at 10 degrees it dosent have enough power to keep the tires rolling at 15mph needed for the smog test. The tech gives it alot of gas to get it going then brings it down to 15mph and it dies
Old 07-11-2011, 09:56 PM
1stgenboy's Avatar
Originally Posted by pennywize
so my 82 22r failed smog at idle today.
heres the numbers...
first test
HC
max GP Measured
250 350 676
CO%
max GP Measured
2.00 3.50 6.01
second test after some adjustments
HC
max GP Measured
250 350 361
CO%
max GP Measured
2.00 3.50 4.01
at 2500rpm it is perfect
hc
max gp meas
200 400 60
co%
max gp meas
2.00 3.50 0.05
recently rebuilt carb. replaced almost all the vacuum lines. was running premium fuel, recent oil change and spark plugs.
any ideas what to check or change to make this thing pass? im open to all ideas
thanks!
Your idle circuit is flooding out. Once you open up the throttle the idle circuit is likely still flooding but it contributes little to volume of air now going through. I would check the float level height for correctness.
1stgenboy
Old 07-11-2011, 09:57 PM
  #25
what size tires do you have? maybe you should put some stock tires back on and smog it
Old 07-12-2011, 01:37 PM
  #26
TheChewMaster's Avatar
bump cat....I always have two stock cats because they come out super easy, no weld. One for smogging and one for everyday driving.
Old 07-13-2011, 04:16 PM
  #27
bonsai4rnr's Avatar
smog
I run 41's on it, the smog tech says the tires have nothing to do with it. I questioned that myself
Old 07-13-2011, 05:44 PM
  #28
yea put some smaller tires on and find another shop
Old 07-13-2011, 06:11 PM
  #29
toyotaguy68's Avatar
hey im right next door i can just pick that puppy up on a uhaul trailer and bring it back to AZ.
Old 09-14-2011, 10:58 AM
  #30
xjfiles's Avatar
I had really high emissions and it was due to an exhaust leak ahead of the oxygen sensor. It was pulling in clean air and the O2 sensor thought it was running lean so it started dumping fuel.
Old 10-21-2011, 09:26 PM
  #31
neockder's Avatar
Originally Posted by Sensei
x2, change the cat, retard your timing a couple degrees and run 1 pint of rubbing alcohol to 5 gallons gas.
How DO you change the timing? The only thing i can think of is physically moving the chain over a tooth.. Which would be way off. I did notice an adjustment on the distributor cap, as well as the fanned-slotted bracket that fixes the distributor to the block... But honestly I have little experience tuning a carburated motor.
Old 10-22-2011, 09:51 AM
  #32
you move the entire distributor to adjust timing
ladybugRC
458
08-21-2020 10:41 AM
Truckwithoutaname
10-03-2015 03:41 PM
bryan34w
12
09-30-2015 02:50 PM
dbollier123
09-29-2015 05:23 PM
taraf
09-25-2015 02:57 PM
Quick Reply: Failed Smog - Gross Polluter - Now What?
