Pre 84 Trucks 1st gen pickups
Drain Plugs... They're all stuck
Old 02-27-2012, 02:10 PM
Bingle's Avatar
Drain and refill should do, depends on how nasty it is I guess. If it was WAY bad I might run the cheapest stuff I could find for a little while, drain and put in some good stuff. I run all synth in everything in my '81 and have been very pleased but I flog it pretty hard so it's minor insurance.
Old 02-27-2012, 02:31 PM
83Toyota88's Avatar
Define if its "WAY" bad. Like color or texture? Both?
Old 02-27-2012, 04:38 PM
83
83's Avatar
Super dark and thick. Foamy is not good. Lot's of little metal shavings, not good. Some metal shavings might be normal, but a lot is not, and chunks are not good.
But yeah, if you've got a manual tranny, changing the fluid is a good thing, and the sooner the better. If you drive it around and get it nice & warmed up, you should be able to get the crap out without worrying about flushing.
Also, beware hijacking someone else's thread. You can start your own if you have a lot of questions.
Old 02-27-2012, 06:16 PM
ledzeppelin3270's Avatar
This is what I took out of my axles. I'd say that's pretty bad! I used an air compressor to blow out the diff, seemed to work well.... there was no way that this stuff would have dripped out on its own.
Old 02-28-2012, 08:18 AM
  #25
Boon's Avatar
wow.
mine wasn't quite this bad, but i did notice a change in both drivability and mileage.
Old 04-13-2012, 06:54 PM
  #26
Pumpkinyota's Avatar
I went to the Quick-Lube, and laughed the whole time as they fought the plugs for 2 hours with an extractor. Best hundred bucks I ever spent.
Old 06-01-2014, 12:40 PM
  #27
yay1904's Avatar
drain plugs stuck ?
I had the same prolem a couple times I found the only way to get em unstuck is to use an air impact wrench should come right out good luck!
Originally Posted by ledzeppelin3270
Today I wanted to change diff, transfer, and transmission fluid, but when I crawled under, I could not get the drain plugs or the filler plugs off I've got some Rust Bomb soaking on them right now and I'll take some heat to them tomorrow, but I was just wondering if anybody has encountered a similar situation and has any tips. Also, if anyone knows where I can get replacement plugs, that would be nice. A brief visit to the O'Reilly website didn't turn up any, and I would really like to replace them. Thanks!
hiluxinargentina
09-30-2015 05:51 PM
Boomer8404
09-17-2015 07:59 AM
gp66
09-14-2015 12:10 AM
Boomer8404
09-10-2015 09:01 AM
bootscootboogie
09-05-2015 05:57 AM
Quick Reply: Drain Plugs... They're all stuck
