CA Smog hell - 17%02 Reading
Hi All - new to the the forum, but glad to have found it. Purchased a 83 4wd Truck (22r) from a ranch for 300 bucks. Got it running and the thing is in decent shape for being abused the way it was!
Here is what has been done so far:
- Rebuilt Carb
- New dist cap, plugs, wires
- New fuel filter, oil + filter, radiator hoses, wheel bearings, and other basic PM.
- New Cat and muffler
- Replaced all the gaskets in the exhaust (Engine --> manifold, Manifold-->pipe, Pipe--->Cat)
- Helicoiled all the manifold studs back in place can torque to spec w/o a problem
- Plugged some minor leaks in exhaust that where found with soap and attached shop vac (blowing not sucking). Found more small leaks on the new welds cat/muffler then on the old down pipe!
- I think I have fixed just about every minor leak in the exhaust.
http://www.autoshop101.com/forms/h56.pdf
http://www.autoshop101.com/forms/h55.pdf
Since you did not post all of your smog readings, you'll have to figure out what-is-what.
defrag4
07-31-2015 10:50 AM
coffey50
07-28-2015 10:55 AM
