A/C compressor mount
Hey Guys adding factory A/C to my truck. I'm working on mounting the compressor to the motor, but I can't seem to figure out exactly where the bracket, compressor, and motor fit together. I understand the compressor goes above the air pump but I'm stuck after that. Looking for a few pics of an installed compressor. Hopefully a picture will be worth a 1000 words. I have all the factory brackets shown in the diagram (bottom image) Cali spec. thanks
Attachment 90999
Attachment 90998
Attachment 90999
Attachment 90998
Attachment 90999
Attachment 90998
Attachment 90999
Attachment 90998
I have everything pictured in top diagram (federal) on my truck. Giant bracket 88431 bolts to block which top two ears of compressor bolts to. Your pictured ac compressor is missing back ear? Bad pic angle? AIR pump style? Is that smaller bracket 88431 (lower diagram) in picture? Do you think you have to marry both brackets for AIR pump? Mine uses idler pulley for adjust. Looks like you'll use AIR pump to adjust belt. 88432. Yeah, I know clear as mud.
help
I've been struggling with this A/C compressor bracket(s) for about two weeks. The FSM doesn't show where (how) the bracket(s) mount to the motor. Again I'm using the RN34L, 38L series (for calif) equipment. Can someone please post a pick or two of their A/C compressor, I 'd really appreciate it. thanks tony
klavender1
08-15-2015 01:51 PM
skoti89
07-08-2015 12:05 AM
