Pre 84 Trucks 1st gen pickups
Axle U-Bolts
Old 05-09-2011, 07:31 AM
541SR5's Avatar
Question Axle U-Bolts
Does anyone know where I can get some stock length axle U-bolts (front and rear)? I'm doing a stock rebuild on my '81 and the original U-bolts and nuts are in pretty rough shape. I figured, I might as well replace them with new ones, however all I'm finding are the longer U-bolts for the flip kits and suspension lift kits (which I'm guessing would hang down a little too low).
Old 05-09-2011, 07:46 AM
4Crawler's Avatar
Rancho (http://gorancho.com/catalog.php) carries a large selection of u-bolts, look in the Master Catalog Supplement (Specification Chart) and match up the shape and size to what you need. No problem using a longer than stock u-bolt, they usually have extra long threads and you just cut them to length after installing them.
Or if you have a local spring/suspension shop, they should be able to bend you up a set.
Old 05-09-2011, 07:49 AM
Greg_Canada's Avatar
I bought new ones from toyota, was about 100 bucks i believe.
Old 05-09-2011, 08:56 AM
541SR5's Avatar
Yeah I haven't checked the dealership yet, I figured they wouldn't have them being just about everything else I've checked on has been discontinued. I'll check with those guys too though.
Old 05-09-2011, 09:08 AM
JustDSM's Avatar
If this would have been a week or two ago, I just threw away a complete set off my '83 that were in great shape. Sorry man.
Old 05-09-2011, 06:56 PM
Yopar's Avatar
Better to use new ones anyway. See 4Crawler's post above, or you can get Old Man Emu replacements from TRDparts4u just give them a call, no affiliation but I always get great service over there. 866-233-4305
The OldManE's are part #OMEU53 for the rear, and #OMEU52 for the front, they come with nuts/washers, about $11-12 each, you need 4 of each part #.
Old 05-09-2011, 07:27 PM
sebastianholmes's Avatar
autozone? or your local equivalent
Old 05-09-2011, 07:28 PM
Nimyad's Avatar
Just get some made, at our local shop they're $8 a piece with nuts and washers
Old 05-10-2011, 09:09 PM
peow130's Avatar
Pohl springs?
They made me a set for my jeep for like 50 bucks.
Old 05-10-2011, 09:36 PM
Nimyad's Avatar
Originally Posted by peow130
Pohl springs?
Six states is where I get mine.
Old 05-11-2011, 08:36 PM
peow130's Avatar
Still haven't gone out there. A friend of mine just got his rear driveline rebuilt, and a double-cardan put on the TCase side. I guess he knew the owners son or somethin.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Axle U-Bolts
