Pre 84 Trucks 1st gen pickups
Aftermarket intake manifold
Old 07-15-2011, 11:15 AM
Unicorndeathmachine's Avatar
Is a openhimer ( I know I spelled it wrong) intake manifold worth getting? Looks good and is for a 20r motor. Asking around 100 bucks and I have never heard of anyone changing the manifold on a 20r before. Thanks.
Old 07-15-2011, 04:58 PM
slacker's Avatar
offenhouser perhaps ?
good units .. but to perform properly you will need more then just the manifold
Old 07-15-2011, 07:44 PM
myyota's Avatar
On a stock engine you might see a small gain, but to really gain anything from it your going to need a header and exhaust, and maybe a low to mid range cam to really gain some noticable performance.
Old 07-16-2011, 12:27 PM
Worth the hundred dollars? And is there any thing to know beforehand? Anything similar to the weber - lack of pcv valve thing?
Old 07-16-2011, 01:38 PM
myyota's Avatar
Yea, its worth the hundred dollars, they go for a lot more than that new.
Old 07-16-2011, 08:34 PM
But is the power worth the hundred?
Old 07-16-2011, 11:34 PM
myyota's Avatar
You might notice a little power gain with just the intake, but if you could also add a header and exhaust that would help a lot also.
What i would do is get the intake, and then later on do a header and exhaust when you can afford it.
Bourbonblues
12-15-2017 05:43 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
JHalcyonM
09-14-2015 01:10 AM
May-39
09-06-2015 01:05 PM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: Aftermarket intake manifold
