Pre 84 Trucks 1st gen pickups
82 toyota 22r timing chain
Old 02-03-2011, 03:20 PM
js894x4's Avatar
Hey there i just purchased an 82 toyota pick up long bed, the timing chain was making that rattling noise so i order a new one online. My has a single timing chain and the one i order has a double roller will it fit. any advice
Old 02-03-2011, 03:24 PM
xxxtreme22r's Avatar
81-82's had a double roller long chain, 83-84 had a single roller long chain. 85-95 had a single roller short chain.
You sure your motor is original? If yours has a single roller chain it's not an 82 motor. And the double roller will not work.
Old 02-03-2011, 03:28 PM
js894x4's Avatar
engine is original 22r carb
Old 02-03-2011, 03:35 PM
what is the production date on the truck?
Old 02-03-2011, 03:36 PM
js894x4's Avatar
july 82
Old 02-03-2011, 03:42 PM
you need the 83 timing chain not the 82.
CHAIN SUB-ASSY 13506-35011 1982.07-1983.07
CHAIN SUB-ASSY 13506-38010 1978.08-1982.07
Old 02-03-2011, 03:57 PM
js894x4's Avatar
So the double wont fit even if i got the full kit
Old 02-03-2011, 04:03 PM
not that I know of. But I could be wrong.
Old 02-03-2011, 04:15 PM
js894x4's Avatar
thanks for the help, i'll wait on the new one before i remove the old one
Old 02-03-2011, 04:33 PM
eightduceyota's Avatar
They also sell a double chain coversion kit with new cover. I think through LC engineering. Might even sell just the cover.
Old 02-03-2011, 04:48 PM
wrong. That kit is to convert an 85-95 22r engine to dual row not a pre-85 engine. The timing cover in that kit will be too short for his motor.
Not sure what's actually involved in changing over those motors to dual row. It might be just as simple as changing over to the 81-82 timing cover. But not sure.
Old 02-03-2011, 04:52 PM
^^^^^^ Oh didn't know it wasn't for older engines just remember seeing it a while back. But you may have something there with the swap thing from an older engine.
Old 02-03-2011, 04:58 PM
herpestes's Avatar
you will need to order a shorter oil pump spline drive for the earlier motor to convert to dual roller chain
Old 02-03-2011, 05:00 PM
If I wanted to look at the different components in the diagrams and parts listings between the two I can probably figure it out. But only gonna do that if the P.O. wants to convert it. Might be a shorter water pump as well, but not 100% on that either.
Old 02-03-2011, 10:00 PM
herpestes's Avatar
good luck on your repair
Old 02-05-2011, 08:07 PM
js894x4's Avatar
well the place i purchased my timing chain will exchange the one i ordered for the 83 version. it seems the did not have the double roller in stock anyway.
Old 02-05-2011, 09:36 PM
herpestes's Avatar
^^^^ fyi
your existing timming cover will work with the dual chain setup.
Old 02-05-2011, 09:38 PM
js894x4's Avatar
what would be the advantage of having the double roller?
Old 02-05-2011, 11:43 PM
herpestes's Avatar
just that you won't need to open it up around the next 120K, heard that the single roller is good just make sure to use the metal backed guides. the single has less drag.
Old 02-06-2011, 06:50 AM
11302 COVER SUB-ASSY, TIMING CHAIN OR BELT 11302-38010 1978.08-1983.07
81-84 timing covers are the same looks like. Guess I should have looked up my parts references.
Quick Reply: 82 toyota 22r timing chain
