Pre 84 Trucks 1st gen pickups
81 pickup wont charge battery
Old 09-26-2010, 10:16 AM
shmitty's Avatar
I have and 81 pickup that wont charge the battery the truck has a new battery and i just installed a new alternator but its almost like the alternator isnt doin anything at all. Does anyone know if there is some kind of exterior regulator or maybe a fuse of some kind that could be blown???
Old 09-26-2010, 10:47 AM
myyota's Avatar
You might have a bad voltage regulator, it mounted on the driver side inner fender.
Old 09-26-2010, 10:52 AM
scottishb's Avatar
Check your grounds. Feel all connections for excess heat. A hot connection is a bad connection.
x2 on voltage regulator
Old 09-26-2010, 06:38 PM
shmitty's Avatar
I just picked up a voltage regulator the old one looks to be in bad shape so ill jump on that tomorrow and double check all my connections, thanks for the tips guys
Old 10-19-2010, 09:40 AM
hilux-1983's Avatar
Sooo, is it fixed?
Old 10-20-2010, 08:03 AM
drokliss's Avatar
I had a fun one when I first got my rig, the guy had put an '86 alternator in it, and hacked together a pig tail connector. Must have been relatively recent, as it wasn't anywhere near wired up right and not charging the battery at all. I managed to use the connector from the external voltage regulator as a splice to hook up to the '81 wiring harness (with lots of help from an uncle).
Curious too...is it fixed?
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: 81 pickup wont charge battery
