Pre 84 Trucks 1st gen pickups
81 pickup multiple questions
Old 08-01-2012, 10:58 AM
Bingle's Avatar
Are you mudding? rock crawling? trail running? Makes a diff in what you want.
A 3.5" should do for ya unless you're unhooking the sway bar and flexing the front out pretty good. Even then you can remedy that with some minor fender well trimming. I have a 1" or 1.5" (don't remember) BL on mine. I don't "like" it, but I don't hate it either. Gave me just enough with the suspension I already had (3-3.5") to not rub with the 35's flexed out.
No PS and 35's would be a bear. Hope you got some guns or go to high steer.
Old 08-01-2012, 01:46 PM
parkerst02's Avatar
I'm goin to do mostly mudding and i will probably end up getting high steer and hopefully power steering. So 3.5 will probably clear 35's or should i get some bl to
Old 08-01-2012, 02:19 PM
Bingle's Avatar
3.5 should be fine for mudding. You're gonna need to go to 5.29 gears to turn those decently as well. might as well do lockers if you're in there. Oh, the money you'll spend!!
All part of owning a yota.
Old 08-01-2012, 02:30 PM
parkerst02's Avatar
Yeah i know it isn't cheap but its a fun project. Only problem is doing this on teenager salary
Old 08-01-2012, 02:38 PM
  #25
SCToy's Avatar
81 3 inch lift on 31s
On 35s
And on 33s.
I got these because the 35s rubbed a little and I wanted better gas mileage from the 33x10.5s.
Have 4.88s, Aussie lockers f/r and high steer. Perfect truck, I dd it and it goes pretty much anywhere I care to go offroad. 4.88s work well with 35s and 33s.
Old 08-01-2012, 03:18 PM
  #26
parkerst02's Avatar
Nice looking truck wish mine looked better. So 33s do good with it how is the gas mileage
Old 08-01-2012, 03:22 PM
  #27
SCToy's Avatar
21 mpg with the camper shell
Old 08-01-2012, 03:45 PM
  #28
parkerst02's Avatar
Any modification to motor
Old 08-01-2012, 06:35 PM
  #29
SCToy's Avatar
Nope, fixed vacuum lines, EGR and exhaust leaks.
Old 08-01-2012, 09:19 PM
  #30
parkerst02's Avatar
thats actually better than i thought it would be with a stock motor and i want to put on a weber carb. and do away with most of the vacuum lines that should help my mpg a little. You have any advice that you would advise a rookie at this to do
Old 08-01-2012, 09:30 PM
  #31
Fossilized
Staff
dropzone's Avatar
https://www.yotatech.com/forums/f114...ly-22r-205845/
Old 08-01-2012, 10:06 PM
  #32
parkerst02's Avatar
Thank you dropzone that thread will help me alot when i go to remove most vacuum lines
Old 09-07-2012, 04:13 AM
  #33
parkerst02's Avatar
well got it desmogged and on the back of the timing cover on a 22r is two hoses on each side are they heater hoses?
Old 09-08-2012, 07:22 PM
  #34
83Toyota88's Avatar
Yea im pretty sure at least one of those runs to the heater core. Those hoses get in the way when I try to take the cover off the motor.
Old 09-09-2012, 10:10 AM
  #35
parkerst02's Avatar
well mine was leaking real bad and was going to block them off but finally fixed that but now another question why is mine getting hot. It idles under carport around 190 and i figure thats about right since its a 180 thermostat but when i go to drive it i know it gets up around 230 or 240 and it kills itself and i just let it cool down. It has new pump and thermostat.
Old 09-15-2012, 01:04 PM
  #36
parkerst02's Avatar
ok another motor problem it starts runs for like 3 seconds and dies its getting gas it started doin this while i was going down the road it just died any ideas of what could be causing this?
Old 10-21-2012, 06:32 AM
  #37
parkerst02's Avatar
need some help on timing. I can get it to run but idles high i have to pump the gas couple times to get it to run. When i go to idle down it starts missing and jumping around so i'm thinking it might be off a tooth on the timing chain what ya'll think?
Old 10-21-2012, 08:29 AM
  #38
westjohns yota's Avatar
you let it get hot?? if it was running fine before it got hot your timing must have been on then, if its rnning weird after you might have poped a head gasket
Old 10-27-2012, 09:43 AM
  #39
parkerst02's Avatar
its kinda the opposite it runs weird cold then when it gets hot it runs good and can get it to idle down. has good head gasket i'm starting to think its a cracked head
Old 10-27-2012, 11:54 AM
  #40
firstgen88's Avatar
I really like your truck.
Quick Reply: 81 pickup multiple questions
