Pre 84 Trucks 1st gen pickups
81 2wd tranny in 82 4wd
Old 12-21-2012, 06:35 AM
fallingacorntf's Avatar
I just got a 81 diesel 1L and 2wd tranny. The bell housing on the diesel appears to be the same bolt pattern but the diameter is an inch or two larger so a straight swap is not possible compared along side a 82-83 4wd transmission the transfer case will bolt right in behind the shifter. The cover on top also has to be swapped.Length of transmission is the same from mount to front edge of bell housing.
The gearing should be the same. The extra fuel milage is due to the diesel motors efficiency
Old 12-21-2012, 07:53 AM
Little Elger's Avatar
The little diesel swap will be fun, I still haven't got to start on mine yet, but since the world didn't end yet there may still be time, ha ha.
mskalmus
05-28-2017 07:51 AM
Pedalpwr27
08-13-2015 06:37 AM
yipyip45
08-06-2015 02:05 PM
landrunner
08-05-2015 09:18 PM
Iceman4193
07-15-2015 04:48 PM
Quick Reply: 81 2wd tranny in 82 4wd
