Pre 84 Trucks 1st gen pickups
32/36 weber electric choke
Old 01-19-2014, 04:34 PM
scotts82's Avatar
so I have a 32/36 weber on my 22r I cant get the choke to work ... I got 12volts there only when ignition is on or truck running the problem.. no matter where I set the choke plate tension wise it don't wanna open slowly. I had it work once set the high idle it slowly opened but not matter what it wouldn't close even after the next day snapping the throttle didn't help anyone ever had a problem with this. this is a brand new carb. whats the proper procedure in doing this any help would be great thanks.
Old 01-20-2014, 10:16 PM
Rock N Crawler's Avatar
I'm having the same prob with my weber 38 and it's really annoying being the temperature is below zero almost everyday in the winter where I'm at. Would be nice to here an answer for this question.
Old 01-21-2014, 07:15 AM
KryptoRoxx's Avatar
Sounds like you have a larger amperage than what is needed for the carb IMO. I have mine wired into the stock wiring. Its a round green connector and if I am not mistaken it is the lower left connection. There are 4 possibilities though.
Beamed from my dumb phone using Yotatech
Old 01-21-2014, 07:23 AM
Thanx man that solved it my dum ass had it straight off one of my lines from my battery
Old 01-21-2014, 07:40 AM
KryptoRoxx's Avatar
Yeah that will open it REAL quick lol! Glad I could help out.
Pri$erulz
11-17-2019 08:03 PM
Obmi
10-04-2015 11:30 AM
kawazx636
09-29-2015 08:22 AM
voiddweller
09-28-2015 11:21 PM
Project90
09-24-2015 11:40 PM
Quick Reply: 32/36 weber electric choke
