Pre 84 Trucks 1st gen pickups
20r L52-hd Bonding
Old 05-23-2006, 05:36 AM
WORMGEAR's Avatar
20r L52-hd Bonding
Yestreday Bought A Stock 1980 4x4 That Is 100% Rust Free And The Trans Is Very Sloppy. Will The L52-hd Bolt Up To The 20r Motor And Stock Transfer Case? I Am Very Excited About My New Project And Will Have Some Pics Soon. Thank You For Your Help
Old 05-27-2006, 04:06 PM
kyle_22r's Avatar
yep. might need to clearance the splines on the t-case, to make it slide in all the way, but it's a bolt-up. you'll need to get the clutch fork, disc, pressure plate, throwout bearing slave cylinder, and hub for the L52 though.
also may need to enlarge the hole for the shifter on the tranny, it sticks up a little to the left of where the L43 one comes up.
the main reason the L43 gets sloppy is that the bushings on the side of the tranny that hold the stick wear out. i think you can get new ones from toyota(note: this isn't the standard shifter bushing setup like on most other toyota trannies, these are 2 rubber bushings)
Old 10-24-2013, 05:27 AM
duckmaster88's Avatar
Bout to dot he same swap in mine any idea what the long list of things I'll need would cost and where can I get them from?
Old 10-24-2013, 05:51 AM
Fossilized
Staff
dropzone's Avatar
The spline issue is with the t/c splines, on some 79/80 transfercases
if your t/c splines look like below, you are good to go:
Old 10-24-2013, 05:57 AM
Thanks a million dropzone I was just wondering about all this and the fix is simple enough.
Old 10-26-2013, 02:47 AM
Fossilized
Staff
dropzone's Avatar
Any time. I ran into this issue on a t/c i pulled out of an '80 parts truck. Big Mike of Marlin Crawler either posted the top two pics here or I pulled them from Marlin's forum a few years ago. This question comes up every now and then so I went ahead and saved'em..
Old 10-27-2013, 08:37 AM
Also love your notebook of ideas found a lot of good info int there hope you don't mind me coppying a few ideas you had?
Old 10-27-2013, 01:39 PM
Fossilized
Staff
dropzone's Avatar
That is what it is there for.to share info..most of the stuff I found on assorted forums and instead of a ton of bookmarks I borrowed the notebook thread idea from mr stubs on pirate.
kawazx636
10-06-2021 03:03 PM
presto30
Engine Swaps
12-10-2015 12:01 PM
urabus
11-10-2015 07:38 PM
83
18
09-21-2015 06:15 PM
LucasF249
09-08-2015 01:17 PM
Quick Reply: 20r L52-hd Bonding
