20r backfiring in high gear please help
i've got a 80 toyota 4x4 20r motor the other day i was coming up a hill in 4th gear when it started cutting in and out and backfiring, by the time i got home it would hardly pull it self up the slightest incline in any gear but 1 or 2.
So i just started checkin everything this is what ive done so far
new fuel pump
new fuel filter
new carburetor
new plugs, wire, cap, and button
new coil
so none of that helped ive checked the valves, did a compression test got 110psi on each, timings good, checked for vacuum leaks none found, ive tested the spark its all good. ive put new gas in, i though maybe the clutch was slipping so i put one in yesterday and it still acting up.
it will run just a smooth as can be till u hit 3rd gear and up, as soon as u get it under a load it starts cutting in and out and backfiring thur the carb and bucking and jumping, ive tested and checked bout all i know to anyones help would be great, thanks
new fuel pump
new fuel filter
new carburetor
new coil
i would check the fuel lines, i had the original on mine, it would plug up the stock fuel filter in no time, i always put on a really large filter on my trucks like off a 80s ford truck.
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Poncho0206
07-10-2015 06:21 PM
