Pre 84 Trucks 1st gen pickups
20/22R hybrid timing issuse
Old 06-09-2013, 09:47 AM
Rollz79's Avatar
So some info on the engine. 79 20R head been milled to make flat. EB Over sized valves and a mild port and polish,LC dual valve springs, LC adj cam gear and bigger cam 290.
81 22R block with dome pistons,all ARP's,MLS head gasket, everything else is OE replacements. I have a weber 38 on it also.
I can not get the engine to time right. it pings under a heavy load. I can pull 1st and 2nd with no issue 3rd and 4th ping under throttle. I have a LC pro Dizzy. I can't get it to line up to 0btdc with a timing light with out it dieing. So its set a 8btdc with out vac ad hooked up. Ive tried to move the dizzy a tooth back wont fire that way.
any idea's?
Old 06-13-2013, 03:25 PM
Yopar's Avatar
Did you degree the cam in? Make sure it isn't off a tooth.
Also, make sure the fuel octane is good for your compression ratio.
06-01-2021 01:51 PM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Quick Reply: 20/22R hybrid timing issuse
