1983 Pickup Fusible Link?
Are there any fusible links in a 1983 Toyota Pickup? My battery blew, and now my truck wont even click over to accessory and I replaced all the fuse box fuses. My only other clue is that I blew a link somewhere, but I don't have a clue where that would be.
Are there any?
Is there another possibility?
Are there any?
fuse links are right off of the positive battery cable ... @ the battery .
there are 2 , and they can be identified with the green plugs that connect them to the wire harness ... 1 is a single wire and one a double .
just give them a good "tug" .. and if they break .. there toast .
Look at the fusible links for a wrinkled up area, which usually means it has overheated and broken. You can buy a section of link wire at most any auto parts store. Get the same color as the one that is bad and around 12" long.
If link is broken, you need to find out what caused it, to be on the the safe side
09-04-2015 09:27 AM
