1982 SBC Swap
#43
Today, we didnt get the tranny mounted just yet but we got pretty far. We got the heater box out and cut the shifter hole longer. As we jacked the tranny up, the transfer case hit the tunnel, so we had to cut a small square out. Next we'll have to cut one identical for the trans to come up some more. after we have that mounted we'll weld sheet metal over them to cover it up.
Pictures:
I'm back at college again this week, so more updates and pictures this weekend. Still waiting on the fuel pump to come in as well.
#44
cstone94 I had to cut almost the exact same hole in my floor to clear the tcase right along the seat mount. Just boxed over it too.
#47
ya vance I want to do another Toyota at a later date with the 5.3 most likely a 4 door runner for the wife. I didn't know you could use D60 and cheap in the same sentence...
Awesome dude, can't wait to see how yours turns out!
#49
Depends. Stock probably an open diff. Unless someone has put a posi/limited slip or a locker in it already. Jack both tires in the air with tranny in neutral and spin one tire. If opposite tire spins opposite way as the tire your spinning it's open. If they both spin the same way it's locked or limited slip.
#50
#52
#53
#54
No spool is like 135 bucks it replace your carrier and spider gear and makes it one solid unit that has no failure points. I doubt any lunch box locker will be able to handle the new power this truck will have and detroits still will eat tires so either save money and go spool or spend big bucks on zip or arb lockers or do a Tacoma e locker swap.
#55
#57
Welp the transmission is mounted! Tomorrow(Sunday) we are gonna weld the motor mounts in and hopefully bolt the motor in and possibly have it running! I'll take pictures/videos of it all tomorrow!
#58
Travis, what motor mounts did you and your friend use? We the engine in and the mounts were about 5 inches far from the mounting holes on each side. I'm thinking I need Rod Style mounts.
#59
I used the old chevy type mount with 1 bolt coming up from the bottom center. I built the mount plate to the frame with 3" channel and 1/4" plate welded to the end where the motor mount sits on it. I'm not sure what my brothers truck has. I'll go out and take a few pics and post them up tonight for ya.
#60
Here are mine I'm using. They been in the truck for about 5 years. Although I think I might go solid.
Here are my brothers. His has a solid mount off the engine to a rubber bushing at the frame.
