Pre 84 Trucks 1st gen pickups
1982 SBC Swap
Old 01-15-2013, 07:04 PM
travis_h's Avatar
Originally Posted by cstone94
Travis, what did you do about a fuel pump? I was told I need to get an Inline Fuel Pump.
I have a fuel cell mounted in my bed under my tool box and I mounted a fuel pump next to my fuel cell. I just ran new line because I wanted bigger line then connected both ends with rubber hose. I would just get a Holley red or something like that and mount as close to the fuel tank as you can.
Old 01-15-2013, 07:09 PM
cstone94's Avatar
Check that link above your post, would that work for my setup.
Old 01-15-2013, 07:19 PM
travis_h's Avatar
It probably would but here is another link. (http://www.kmjent.com/cart/115gph-el...-mopar-gm.html) some what cheaper than a Holley red, but similar specs. It don't give psi or gph on the other one.
Old 01-15-2013, 07:28 PM
cstone94's Avatar
cstone94ravis_h;52027374]It probably would but here is another link. (http://www.kmjent.com/cart/115gph-el...-mopar-gm.html) some what cheaper than a Holley red, but similar specs. It don't give psi or gph on the other one.[/QUOTE]
That one looks more official. I'll order it tomorrow, thanks for the help
Old 01-16-2013, 08:25 AM
  #25
cstone94's Avatar
Got these motor mounts ordered: http://www.summitracing.com/parts/trd-4227
And ordered the inline fuel pump from KMJ: http://www.kmjent.com/cart/115gph-el...-mopar-gm.html
I'll have some pictures up this weekend of how far I get.
Old 01-16-2013, 08:33 AM
  #26
travis_h's Avatar
Solid mount huh? I was thinking about doing that too, but mine is now going trail only not street. You street yours? Gonna feel more vibrations.
Old 01-16-2013, 10:24 AM
  #27
cstone94's Avatar
I'll trail it mostly. Probably street it to college every once in a while (hour drive, not daily). If I find some rubber mounts on craigslist I may pick them up, but until then I'll run solid. I DD a 95 Wrangler 2.5L, 35's and stock gearing. Driving the truck on the road will be 10x better than what I'm used to... 4k RPM's up hills. Lmao.
Old 01-16-2013, 11:52 AM
  #28
cstone94's Avatar
Travis, did you wire your inline pump with an ignition wire so the pump would only run with the key installed. I kind of want to run a separate switch for security purposes.
Old 01-16-2013, 06:37 PM
  #29
maachine's Avatar
you should run the fuel pump on a oil pressure switch or something similar. that way, if you get into an accident and your oil pressure drops off (due to the engine shutting off), it will kill your fuel pump. otheriwise if you run it off a keyed ignition source, get into an accident.....there is a possibility that your fuel pump will continue to run........feed a possible fire......burn a lot of stuff.
Old 01-16-2013, 06:48 PM
  #30
cstone94's Avatar
Yeah I read about that somewhere. I'll definitely look into that. Of course if it, and only it did burn... New toy!! haha
Old 01-16-2013, 07:21 PM
  #31
travis_h's Avatar
On a toggle with a keyed power feeding the toggle so it'll shut off with the ignition if you forget the toggle and you could just shut off the pump with the key on too.
Old 01-16-2013, 07:22 PM
  #32
maachine's Avatar
hahaha. on the dodge forum i frequent, i was asking about putting an electric fuel pump on my dodge. a guy responded that a friend of his almost got burned alive because of this. he ended just losing a hand.....but serious stuff to consider. i'd say stick with a manual fuel pump if your engine accepts one. they are cheap and reliable enough. i stayed with the manual pump.
Old 01-19-2013, 07:53 AM
  #33
cstone94's Avatar
Hey Travis, do you have those engine bay pictures?
Old 01-19-2013, 09:50 AM
  #34
travis_h's Avatar
Ya I'll go take some today and post up for ya. And specific pics?
Old 01-19-2013, 11:17 AM
  #35
travis_h's Avatar
Old 01-19-2013, 08:54 PM
  #36
cstone94's Avatar
Thanks for the pictures.
We're having some major fitment issues. The transmission is positioned where the crossmember holes line up.
How important is that box in front of the shifter hole?
Old 01-19-2013, 09:51 PM
  #37
travis_h's Avatar
What tranny you running? My brother in law has a 4 speed sm465 in his yota with a 350 and the people who built it had to cut the floor way forward, cut the bottom of the dash and bent his shifter way back. We're gonna do a th350 swap later. It's parked in my driveway so I can post some pics of how his stuff is done too if you need.
Old 01-20-2013, 06:20 AM
  #38
cstone94's Avatar
I'm running the same trans. Please post some pics.
Old 01-20-2013, 07:21 AM
  #39
travis_h's Avatar
Between the two trucks i can get more pics of anything that i have here. The one in my driveway he bought as is and it has some good parts, but a lot of it is not finished or they just did a crappy job on it. He is in the process of getting the parts gathered up so we can start a total tear down and rebuild.
Here are a few pics of the inside how they did the shifter. It comes out under the dash, but the truck is a 94 so the dash is gonna be a little different.
I didn't get much pics from below because it sounded like you had the crossmember lined up. His has a different crossmember made of plate and angle. It needs to be redone when we go to th350. Also they just welded his crossmember right to the frame. Here is one of the crossmember.
Old 01-20-2013, 07:32 AM
  #40
cstone94's Avatar
Pm me your number if you don't mind
Quick Reply: 1982 SBC Swap
