1980 Toyota Pickup Tach Issues
Hey guys I have a 1980 Totoya pickup dlx. I bought a sr5 cluster from a junk yard to swap into my truck. When ignition is turned on the tach jumps up to 2.5k and stays there whether running or not. I wired up signal from the ignitor where you are supposed to grab signal and pinned it into the correct pin on the cluster but no difference. So I dove into the cluster to see if anything was wrong and found a burnt resistor on the circuit board, as seen in the pictures. If anyone has a picture of the board on their tach I need to see what band color pattern the resistor is (or the resistor value) so I can solder in a new one. Thank you!
Hey each person, i picked up this 81 a pair days ago, astonishingly i only paid $two hundred!!! In any case, it has a few problems, but runs awesome. The one problem i tinkered with all day is the Tachometer...It dosn't paintings... I tried to trace wires to peer if perhaps that was the issue, but i got lost lol. How am i able to test it to look if maybe its just wiring, or if i want to replacce it?
192.168.100.1 192.168.1.1
ghassan
06-17-2018 12:15 AM
