Pre 84 Trucks 1st gen pickups
1980 Exhaust manifold heat shield question
Old 08-22-2006, 10:47 PM
freakycody's Avatar
I just purchased a 1980 toyota pickup 2wd (gas reasons, the 4x4 is a killer on gas) and the exhaust manifold is cracked. So in repairing it I am wondering that when I place it back on do I need to keep the thin metal heat shield? Is it that essential? If I don't put it back on then I only need to purchase one gasket rather than two and plus, i could see the heat shield being the cause of the cracked manifold by keeping heat in rather than letting it out. Any information would be greatly appreciated. Thanks.
BTW I am talking about a 20r engine.
Old 08-23-2006, 09:23 AM
freakycody's Avatar
anyone?? I was planning on dealing with this issue after work and would like some input. Thanks.
Old 08-23-2006, 12:57 PM
80 mini's Avatar
Since I put a header on my 20r I don't run the heat sheild. Runs fine for me...I guess the function would be to keep the heat away from plug wires? Just my .02
Ryan
Old 08-23-2006, 03:07 PM
freakycody's Avatar
thanks. that is what I figured also. I have no issues with my header on my 22r in my 90 toyota 4x4 affecting the plug wires and I did not put the heat shield on that, so i will just not bother installing the heat shield on the 1980. Plus I have a 1987 3/4 ton 4x4 chevy and the heat shield has caused me to crack 3 manifolds. once i removed it i have not cracked a single manifold. Just never delt with this old of toyota engine and thought I would check.
Old 08-23-2006, 03:21 PM
Sponsor
Tofer's Avatar
when i rebuilt the 22r in my 81 i left the heat sheild thing out...
Old 08-24-2006, 07:56 AM
freakycody's Avatar
well, i left it off and have no issues. Dang it sure sounds quiter after fixing the major exhaust leak. Thanks again for the info.
Old 08-24-2006, 03:39 PM
kyle_22r's Avatar
those heat shields were junk. i pitched mine back when i had a 20R in my truck, made no real difference that i could tell.
toyota switched to a much better design in '83 or '84, part of the heat shield was incorporated into the gasket, and the outer half bolts on to the manifold with 3 bolts.
Old 08-28-2006, 04:34 PM
Ditchpig's Avatar
Yup I junked mine as well on a '78 20R. All they served back in the day other than a "shield" was to heat a little air for the engine.... just a pile of aluminum crap.
Old 05-25-2013, 06:09 PM
Richard Facey's Avatar
Heat shield
Just so you guys know you need that shield to pass smog in California. Bought my truck without one and having trouble trying to find one. It's the final piece to the puzzle, going to junk yard Tuesday
Old 10-10-2016, 10:48 AM
MaxineThePickup's Avatar
Hi,
I am trying to desmog Maxine, but her manifold heat shield fasteners seem melted. Can I grind them off and still reuse the shield?
Cheers
tj884Rdlx
08-28-2015 12:04 PM
DrZero
18
07-24-2015 11:31 PM
PlayAwhile
07-20-2015 11:36 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 1980 Exhaust manifold heat shield question
