Pre 84 Trucks 1st gen pickups
1977 chinook distributor cap and carb
Old 01-21-2011, 01:15 PM
terratek's Avatar
I recently picked up a 1977 toyota chinook. Managed to fix quite a few issues (it sat for 5+ years), and it is now running / idling fine.
1) The distributor cap on the vehicle has 2 screws to hold it on, every replacement I have seen has clips. (1st photo is my cap, 2nd is replacement) Any idea where I can find a replacement or find some clips I can screw on to use the replacement?
2) I am assuming from back to front on the passenger side of the carb, screw 1 is fast idle, screw 2 is idle, and screw 3 is air/fuel. What is the factory setting for the fuel air mixture, as I inadvertently messed with it.
Thanks in advance, and sorry if these are stupid questions, searched the forum and googled for an answer before I asked.
Trin
Attached Thumbnails 1977 chinook distributor cap and carb-dist1.jpg   1977 chinook distributor cap and carb-dist2.jpg
Old 01-21-2011, 02:32 PM
swampfox's Avatar
Someone might have changed the dist, so try asking for a newer style cap.
Old 01-21-2011, 02:37 PM
terratek's Avatar
good call, i just checked the newer style caps and it looks like a match, will take it down to make sure. I did the stupid thing and assumed that when the previous owner said "everything is original", they meant it.
Old 01-21-2011, 03:06 PM
buckwheat's Avatar
The cap on my 1980 20r has the 2 screws also. I bought the truck 4 or 5 years ago and changed the cap right after I bought it. I think it is the original motor and distributor, Napa had the right part.
Blamalam
03-12-2022 07:34 AM
Sleaker
08-26-2020 06:03 AM
raptor510
02-17-2017 07:11 AM
yota_Q
10-05-2015 12:30 PM
msane99
07-11-2015 08:08 PM
Quick Reply: 1977 chinook distributor cap and carb
