Pre 84 Trucks 1st gen pickups
1976 truck has to pass california smog
Old 03-25-2012, 12:53 AM
76 chinook's Avatar
I just bought a 1976 toyota chinook, from a storage yard. Until a month ago it hadn't ran for two years. I installed new plugs, plug wires, distributor cap and rotor, breaker points, air filter, fuel filter, oil change, I'm sure you know the routine going through a used rig for the first time. Anyhow it runs nice. I do however have to pass california smog to finish registering it. It has a smog pump but the smog/AC belt has been removed, obviously I can put a belt back on it but I want to know it's working properly before I go to smog it. If anyone is familular with the emissions system in these old trucks, I would be greatful for any tips on getting it back to factory specs.
Thanks
Old 04-13-2012, 06:16 PM
Pumpkinyota's Avatar
Good luck!
Old 04-13-2012, 06:20 PM
Depending on where you live in CA, emissions regs can be pretty relaxed on the older trucks. Start by getting a pre-check, you may be OK right out of the gate. If you aren't... it will be painful.
Replace:
EGR (I promise it doesn't work anymore)
O2 sensor
Then try the pre-check again. You may have to replace VSV's, the computer, etc., if you don't get by at this point.
Old 08-05-2020, 09:28 AM
Chinooked's Avatar
1976 Truck Want to pass smog.. once.
Hey there,
I'm currently trying to pass smog in ca in a town that I only need to pass once for registration. It is non-cat. I know i need the smog pump and connections , does anyone have a list of parts and also potential resources to buy? Ill start checking pick n pull inventories but wondering if anyone here has ideas or more information. Thank you!
Old 08-29-2020, 08:03 PM
nottoshabi's Avatar
Im also entrusted in what you find. I have 78 and live in La need to pass my as well. Please post what you find.
Old 08-29-2020, 08:14 PM
moto809's Avatar
This thread died 8 1/2 years ago. Might be better off creating a new one.
MaK92-4RnR's Avatar
Go take it to get smogged and post the sheet. We need some sort of basis to work on that explains why you failed (or passed)
irv
06-09-2019 07:54 PM
xylicon
06-30-2012 07:17 PM
kdogy313
12-15-2010 12:25 PM
Cornbinder Bob
05-22-2009 10:49 AM
Jared Ajlouny
12
12-08-2004 02:30 PM
Quick Reply: 1976 truck has to pass california smog
