Pre 84 Trucks 1st gen pickups
16 in. Rims on 1st gen trucks
Old 07-24-2012, 02:06 AM
digz's Avatar
Is there such a thing as 16 inch rims for my 1982 toyota 4x4 truck? I was wondering if they exist or is it a dumb question?
please fill me in or tell me you finally found they last guy on earth that doesn't know the answer to that.
THANKEE
Old 07-24-2012, 03:38 AM
Bigdady's Avatar
Yes dumb question, but yes you can buy 16in. rims for a first gen. I had Tundra rims on my 1986 4 runner and they looked good.
Old 07-24-2012, 06:05 AM
waskillywabbit's Avatar
Typically IFS rims don't fit on SFA without wheel spacers.
:wabbit2:
Old 07-24-2012, 06:29 AM
Bingle's Avatar
I did some research on this myself. I want to get duratracs in 35's so I gotta go to 16's. You want a 6 on 5.5 pattern with a MAX of 3 3/8" backspacing or wheel spacers to make up the diff. At least that's what my research on here tells me. If I'm wrong, someone please correct me before I buy the wheels.
Old 07-24-2012, 06:31 AM
Greg_Canada's Avatar
Your truck will explode if you put 16" rims on it.
Seriously, yes they should fit fine. It's just a different rim diameter, bigger typically means more space. It also gives you clearance to do the tacoma or tundra brake swap (fror or sky sells the kit i believe).
Old 07-24-2012, 07:43 AM
Fossilized
Staff
dropzone's Avatar
IFS rims on a SA truck generally require spacers up front as mentioned.
I have 1 St Gen 4runner SR5 alloys that will not fit my 81 with out spacers and an ifs steel rim that need a spacer.
My 05 Tacoma rims would not fit with out the use of spacers.
1 St Gen IFS 4runner owner's please remember there is another 1 St Gen out there...
Old 07-24-2012, 11:11 AM
enigmaT120's Avatar
[quote=Greg_Canada;51948548]Your truck will explode if you put 16" rims on it.
That's what happened to m... hey, what?
I have 16s on my truck. Pics are in the pic thread, probably on the last page or two as I put them up pretty recently.
bowhunter1640
07-06-2015 08:10 PM
WI Girl
06-25-2015 03:45 AM
Mr.Black
06-21-2015 10:17 AM
Luke
07-12-2002 06:10 AM
95Runner
06-09-2002 08:56 AM
Quick Reply: 16 in. Rims on 1st gen trucks
