PA - 1983 Toyota PU chevy drivetrain (bad trans) $2500
PA - 1983 Toyota PU with chevy drivetrain (bad trans) $2500
'83 yota shortbed
located in PA 17948
350 sbc newer 260hp crate
truck avenger carb
th350 (forward gears burned up, reverse works)
np205
about 5"-7" lift
4.56 gears
rear spooled, wider rear axle from ifs truck, disc braked
front detroit with longfields & chromoly hub gears
high steer
38.5 boggers about quarter tread
truck is currently inspected and was a great wheeler till the trans took a dump
TRANS IS SHOT no desire to fix it
$2500 firm
http://www.youtube.com/watch?v=tnXYc...2&feature=plcp
http://www.youtube.com/watch?v=Q8IR7...feature=relmfu
i have a complete stick shift setup for an extra $500 (sm465, np205, twin stick kit, clutch, pedal)
or you can just get another th350 and put that in and it will be good to go
located in PA 17948
truck avenger carb
np205
about 5"-7" lift
4.56 gears
high steer
$2500 firm
zd92655
03-06-2022 12:58 PM
FS[NorAtl]: 1986 Toyota Pickup 4x4 Extended Cab
77lubr
06-17-2016 05:55 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
