1998 Toyota Tacoma, Spokane WA
1998 Tacoma. Located in Spokane Valley, WA. I'd like 3000 for it, but at this point i'm up for offers.
Things that have been recently replaced:
Headgasket, Two exhaust valves, One injector, ECT, MAF (June last year, if that's recent)
Plugs, wires.
The engine is the 2.7L 3RZ-FE. Doesn't knock, doesn't smoke, just leaks oil. In fact, it's fairly quiet now that I've adjusted the valves.
The truck has a P0303, and a P0300. I'm tired of dealing with it, and being a broke-ass college student i'd rather just drive my honda anyways.
Having said that...
It's a 98, 4x4, shortbed tacoma "TRD". Lifted 2.5" w/ a skyjacker platinum lift kit. It's on some 33x12.5x15's
The title is NOT clear, IIRC it was totalled out sometime in like 04' or 05', and in arizona. It has a reconstructed title.
I'm unsure of the mileage. The guy i bought it from said 150k, then said 170k.
My guess is that it's probably between 170k and 200k
The frame ISN'T rusted to all hell, and looks pretty darn good.
Both sides of the bed are like this. Somebody took the support struts that run from the frame to the bed off, and this is what happened.
Whoever owned the truck before me hauled too much weight in it, or did something, because the tailgate is beyond ˟˟˟˟ed up.
Call/text/PM me on here
Bryan
509-991-5481
Plugs, wires.
Having said that...
Bryan
509-991-5481
TTT:
I want 2000 for this rig.
It needs a new head. Did a wet/dry compression test, cyl 3 is dead with 50 PSI wet AND dry. So, my guess is cracked head or stuck valve. It has new exhaust valves in that cylinder so i'm not sure if it's stuck, but i'm leaning more towards cracked.
I'm tired of working on it, and i just don't have the cash to actually fix it.
