FS[GreatLakes]: 22RE Performance motor and Marlin drivetrain
Hello,
I'm currently redoing my 1985 4Runner. I bought a motor from 22RE Performance and installed it myself back in 2016. I put the motor, new trans and transfer and rebuilt the axles in the truck. I drove it intermittently till around 2021. Truck was always garaged. Since 2021 I made plans to put a 1UZFE in so the truck has been slowly worked on. The motor has been started or turned over to keep it lubed. I'm not sure the miles after the swap - I would say around 2,000 miles - life gets busy with 3 kids.
Asking $5,000 for everything or make an offer. I broke the engine and set the timing according to the guidelines at 22RE performance and used the high zinc oil.
Here are the details:
22RE Performance Stage 2.5
LC Dual row timing chain
LCE street headers with egr block plates
LCE big bore throttle body
LCE Harmonic balancer
PSC Power steering kit
LCE HO 140 amp alternator
New coolant and vacuum lines
Motor is ready to go and is very reliable
Marlin Crawler W56A HD Trans
Marlin Crawler 4.70:1 transfer case complete
Oversized clutch with steel braided clutch lines
I also have the stock axles that have been rebuilt and strengthened. I used all parts from Marlin Crawler with WabFab rebuilt locking hubs. 4.88 stock gears.
