Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
What You Never Knew About Gauges
Old 01-20-2009, 02:02 PM
hross14's Avatar
I was working on an old Jaguar (72 XJ6) with an aftermarket fuel pump running 6 psi. To much pressure and it pushes past the floats and the carbs (dual strombergs) puke fuel. So i bought a Autozone regulator and fuel pressure gauge to dial in the pressure. Tested pump pressure and the gauge (1-15psi) was only reading 2 psi. Knock it a bit and it would go between 1-5 psi.
So, i started reading up on gauges came to find out most gauges bought in the stores arent accurate at all. They can be off by as much as 20%. But there are rated gauges that tell you there specs i.e.. 3/2/3 Basically saying that basically this gauge is most accurate within 60% of its working pressure--the other common rating it 1.5% within the swing. AND--they are usually cheaper than store bought gauges!!!! There is alot to be learned about gauges that i couldnt possibly cover here.....but wanted to let you know
So i looked up gauges and bought (Grainger) a 1-5 psi gauge rated at 1.5% accuracy. What did i find--the regulator was bad also and or just a POS (pressure would turn on--then off--then on--then off--it wasnt constant. and was going to max pressure to nothing...
Moral--i will be replacing all my gauges with rated ones from here on out. I dont see how businesses get away with selling these crappy gauges--imagine tire pressure gauge being 20% off.....
Anyways--now you know--and knowing is half the battle
Old 01-21-2009, 10:38 AM
RevNL's Avatar
Three different tire gauges will usually give you three different readings on the same tire.
Reminds me of a quote:
"A man with one watch always knows what time it is. A man with two watches is never quite sure."
Old 01-21-2009, 10:47 AM
DC.Woods's Avatar
^ yep - NEVER carry two compasses! LOST!
Old 01-21-2009, 11:31 AM
22mr2's Avatar
yeah, the garbage that being sold in this country can be more work than the cheap price is worth. If you need a decent pressure gauge, precision gauge ,at least the last one I had my hands on, was made in the united states and 2% accurate. Napa can order a few of them here. I ve also had luck with shraeder-bridgeport tire gauges, there within a pound or 2 of eachother.
Old 01-21-2009, 12:33 PM
hross14's Avatar
Grainger carries them and there are online carries Gauges.com i do believe, that carry them for about half the price. The one i got was accurate to 1.5% of the swing.
That reminds me of another saying (English) "I cant afford to buy cheap"
I think--just like cigarrettes, manufactures should have to put a warning on measuring devices stating their accuracy.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: What You Never Knew About Gauges
