Product Reviews Post your reviews on automotive and expedition-camping gear here
Cold Heat soldering Iron
Old 07-01-2005, 05:22 AM
midiwall's Avatar
Originally Posted by 89macrunner
what i do is i put some solder on the wire and let it dry...than i put the wire with the solder already on it next to what im going to solder it to....than i just heat the solder and let it go again
is this wrong?
Nope, that's effectively tinning the wires. The only suggestion there is that you might want to add additional solder when you re-heat the wires. Think of solder as glue for wires, but you need a good bead for adhesion, it's not like superglue where you _only_ want a thin layer between the pieces.
Kylenicoll33
12-10-2015 06:43 PM
Matthew Perez
09-28-2015 05:43 PM
LotOMiles
09-14-2015 11:45 PM
--Oz--
09-06-2015 01:06 AM
moparbay
09-03-2015 12:48 PM
Quick Reply: Cold Heat soldering Iron
